Originally posted by robwill I have asked for a refund. They refused on the grounds that a trail is available.
Sorry to hear that.
Originally posted by robwill My setup is a K-50 , the 2 WR kit lenses and the 50mm f/1.8 . Neither of the kit lenses are recognized although they are on the supported list.
The kit lenses are supported with the K-50. The DA 50 f1.8 is supported too. (I have it.)
My guess is that the root of the problem is that you haven't installed the relevant modules for K-50 + each of the three lenses. The modules are a small download. The easiest way is this:
1. Open DxO Optics Pro.
2. Click the menu that says "DxO Optics Modules".
3. Click "Download additional DxO Optics Modules..."
4. Find your camera in the list and check the box beside it, then click Next.
5. Find each of your lenses in the list and check the box next to each, then click Next.
6. A list of the modules to be downloaded will be displayed. If you want to add more, click back. When you are ready click Next. Make sure you are connected to the internet.
7. The modules will then be downloaded and installed.
If for some reason that doesn't work, you can download manually using the instructions that @lm4187 linked to. (Using Windows 7 and 8, the instructions didn't work for me, but I just found the Modules folder for DxO and copied the files into it and that worked.)
Originally posted by robwill I have not had the same results as you it seems. I am unable to perform any edits on my file if the lens and/or body are not detected as supported.
If you install the modules that should fix the problem.
Originally posted by robwill In the case of an undetected body, such as my Q7, a message is displayed that says "This image cannot be processed since it was taken with a camera that is not supported by this version of DxO OpticsPro." That is a full stop. No processing of any kind can take place unless the file is converted to a TIFF first. The features like PRIME are unavailable.
Yep, same for me when I tried RAW files taken with my old K100D Super, whether original PEF or converted to DNG.
Originally posted by robwill On a side note I was surprised that all the Nikon 1 series bodies and all the Nikon 1 lenses are supported. I would have thought the Q, based on its popularity in Japan alone, would have more market penetration.
The market for DxO OP in Japan is probably small. The Q doesn't have a lot of presence elsewhere, and a high proportion of people who have the Q wouldn't use RAW or a sophisticated image processing program. (PF members are the exception rather than the rule!)
Originally posted by robwill None of the above is meant in any way against what Des said. I really do appreciate hearing a positive side and constructive feedback.
Thank Rob. Happy to help. Hope you can salvage something from the program once you install the modules. If you still can't get it to work for you, or don't like it, maybe you can pass the licence on to a friend or family member who might get some use from it.
---------- Post added 02-10-15 at 08:50 AM ----------
Originally posted by cake Great pics Des, clear and punchy colors.
Thanks. I can only imagine what I could have got from that camera/lens combination using RAW and some good PP. It only had PEF RAW and came with a really clunky awful editing program. Even the version of Silkypix that came with my K-30 won't touch PEF files from the K100D Super. The implementation of DNG in more recent cameras means less chance of redundancy.
Originally posted by cake I also had a try with the ICC color profile, there is a whole list there to choose from, but I guess I am very wrong going in that area, also not quite sure if can have some good from the visual side...... apologies for my ignorance
Now just discovered in the camera body profiles also the Sony ones on the very bottom of the list , more green to the trees.
@rawr is right: you could go mad trying them all!
Originally posted by cake Still - perhaps not very related to this subject - I miss the most in DXO, the Lightroom so called feature of "adjustments by dragging in the photo" that is really crazy for fine adjustments, in which you can just point inside the picture the color you want to change and drag up and down and see in real time how is adjusting, looks to me just a very fine and precise way to go instead of using the sliders.
Sounds like a great feature. I hope DxO emulate it.
You can individually change each of the colour bands in DxO (e.g. all reds), adjusting hue, saturation and brightness, but what you are describing sounds more sophisticated.
I think there is still a lot of room for additional features without losing the essential simplicity.
