02-18-2015, 03:40 AM - 5 Likes   #1
narual's Avatar
Installing Digital Camera Utility with no CD drive
Wanted to try out the software with my new K3, but I tore the optical drive out of my laptop ages ago to put a second hard drive in, and the CD is in the K3 box in the attic anyway.
I tried downloading it from Ricoh, but the software refuses to install unless it's going in from a CD or is upgrading an existing install.
Googled a bit, couldn't find a fix that didn't require me mucking about with a CD (back to square 1) or a thumb drive (didn't feel like looking for one).
So, I opened up the software package, dug into it, and found a nice lazy fix, at least for Mac users.
You can either have, as some posts mentioned, a thumb drive or CD named S-SW140 (or S-SW150 or S-SW151 - they all work), or you can just have an empty file with the right name in the right location. It's just doing that very basic, very simple check,and then overwriting whatever's in that location with the new version of the program.
Since OS X won't let you just create a file in the Applications folder, just open Utilities > Terminal, paste in the following line of text, and hit enter:
touch /Applications/Digital\ Camera\ Utility\ 5.app
That creates an empty placeholder file in the right location. Then when you install the latest download from the website, it happily completes the installation.
Windows might be different.
Just thought I'd share in case anyone ran across the problem as well.
02-18-2015, 03:59 AM - 3 Likes   #2
Insanely humble
savoche's Avatar
Haven't tried any "magic file" on Windows - I just named one of my memory cards "S-SW140" and the installation went without issues.
04-01-2015, 04:28 PM   #3
Thanks Savoche, that worked like a charm.
04-02-2015, 08:36 AM - 1 Like   #4
narual's Avatar
QuoteOriginally posted by Slade5 Quote
If only the software did...
04-14-2015, 11:07 AM   #5
Wow! Thanks narual, it worked!
11-26-2015, 12:08 PM   #6
QuoteOriginally posted by narual Quote
Thank you! worked perfectly.
12-03-2015, 12:14 PM   #7
Confirmed. Worked with windows 7 Pro 64bit.
Great work around
12-03-2015, 01:22 PM   #8
DCU5 doesn't come with some Pentax cameras like the K-01 or K-50, but you can download it using these procedures and it will process photos from these cameras. DCU5 is great tool for selecting your Custom Image Tone (Bright, Natural, Radiant, etc.) along with the Saturation, Hue, Contrast, etc. settings to customize your in-camera JPEG processing.
12-04-2015, 02:05 AM - 1 Like   #9
An easier way to do it by Windows; make a silent Installation:
1. Mount the iso-file by the free software WinCDEmu mounter (or a similar program)
2. By Explorer navigate to the BIN folder (in the iso-file)
3. Type in "cmd" in the address bar (+enter) or Shift+right click the BIN folder and select "Open Command Prompt here"...
4. Run either the 32 or 64 version of the installation in silent mode by this command: >setupXX.exe /s
(replace XX with the correct number)
And you will make a default installation of DCU5 - without a correct named thumb drive or CD.
12-06-2015, 01:20 AM   #10
hcc
hcc's Avatar
For the benefits of everyone, there seems to be a number of issues with DCU 5.4.2. At least 3 Pentaxians including myself experienced severe crashes with the version 5.4.2:
https://www.pentaxforums.com/forums/32-digital-processing-software-printing/3...y-5-4-2-a.html
I encourage everyone with issues to report them in the above thread. Thank you in advance.
05-19-2016, 08:55 PM   #11
install digital camera utility 5 without CD
Thanks Savoche, that worked like a charm, easy too.
07-02-2016, 07:49 AM   #12
rlg118's Avatar
Outstanding. I extracted DCU5Updater64_5.5.1 to a flash drive named S-SW162. Worked like a charm.
11-10-2016, 01:21 PM   #13
kooks's Avatar
Great tip.. just did it and worked perfect.
Thanks
01-26-2017, 10:35 AM   #14
Great thanks!!
That user interface is one of the ugliest I've ever seen though!!!
01-27-2017, 02:54 PM   #15
lightbox's Avatar
QuoteOriginally posted by rlg118 Quote
I used this trick to install version 5.6.2 in Windows, and it worked insofar as I was able to install DCU.
The program doesn't work, however. When I start it I only see the red splashscreen for a few seconds and then it goes away. There's no further GUI that comes up.
Looking at Task Manager I see that the process is still alive and running, just not displaying anything. I have to kill it manually.
camera, camera utility, cd, drive, file, k3, location, photography, photoshop, software, thumb, utility
Pentax Digital Camera Utility 4 with K-7 Mjason Troubleshooting and Beginner Help 2 07-17-2014 01:41 AM
Problems with Digital Camera Utility 5 EagleEye Digital Processing, Software, and Printing 3 02-13-2014 09:48 PM
Wanted - Acquired: Pentax Digital Camera Utility CD fretlessdavis Sold Items 1 11-08-2013 08:18 PM
cropping with the Digital Camera Utility mturner Pentax K-r 6 02-01-2011 03:22 PM
Pentax Digital Camera Utility 4 tryout (with images) creampuff Digital Processing, Software, and Printing 4 07-10-2009 10:42 AM
All times are GMT -7. The time now is 03:33 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
