Originally posted by noahdsnell Ok, thanks guys.
I guess I'll go with the Dell U2410 and start using Adobe RGB.
Once I edit my image with the wide gamut monitor, I would also like to export it in sRGB for web viewing. How would I do this so that the sRGB version of the photo matches exactly what I see on the wide gamut monitor? When posting to my website and social media, I would need people to see the image just as I did on my wide gamut monitor.
Like what jatrax mentioned.. It's true you do not have any control over others. The color calibration and custom icc is for your own control on your workflow and outputs. Modern color management system already doing a great job! You probably won't see significant color shift form your original palette vs converted sRGB. sRGB will be a little more saturated than AdobeRGB, but that's visually what you would see the difference. In reality, AdobeRGB although mentioned to be wider gamut, but in actual practice, NOT BY MUCH.
If your monitor is sRGB, and you are editing a 16bit image.. Don't let the color depth (16bit) fool you. Since your output is still a monitor (8bit), you will only almost always getting a 8bit output. So when you are editing in RAW software, whatever you are seeing on your screen.. That's exactly what user would get in sRGB file output. Your custom ICC calibration already done it's work beforehand; it converts all the color values for you before it shows on your screen. Therefore, whatever saved into sRGB file, the color space is already been altered by your custom ICC and been converted to sRGB already before your eyes.
I personally think it's funny people would believe in those market advertisements.. Since file format has it's constrain, how is it possible to "expand" more color out of actual format constraints? As funny as it may sound, it's the same reason why people use LAB color and believed it's better or finer toning compare to RGB. But they often forgot, LAB color still won't reach over the file limitation and color depth of 8bit (0~255 levels).. You are in theory, still making the same adjustments! Only going through different calculation to render the color value.. But max value of color still won't go over the limits.
