Riverlady,
Has someone cleaned all the fluff out of the heat sink area?
I tore down one of our laptops some time ago due severe overheating and there was a solid 1/4 inch plug of fluff right across the heat sink (and zero resultant airflow). Cleaned that out and laptop was perfectly cool once more.
Laptops generally draw air in from the bottom, and if they end up being used on beds, floors etc as they tend to do, they basically act as vacuum cleaners and eventually the 'bag' is full.
---------- Post added 11th Jun 2015 at 10:21 AM ----------
I think LR will take a hit with moving everything to an external drive. It writes regularly to the catalogue as each edit step is stored there as well as in the DNG file or sidecar file (depending on your setup), and the previews (assuming these are shifted as well) will load more slowly. Laptop drives are not speed demons but the SATA bus is still way faster than USB, particularly for lots of small writes.
Rather than two computers, consider just buying one good laptop and plugging a decent screen into that. I run a Dell i7 laptop with a Dell 27in IPS monitor plus wireless keyboard/mouse. So far, with a 1Tb drive I still have plenty of storage. One of the beauties of using LR is that you don't end up with multiple copies of each image as the editing is non-destructive and a separate full-res copy of each final edited version is unnecessary. This keeps storage needs under control.
