Thanks, Hogdriver. I've used Samy's in L.A. many times for purchasing, but didn't think of them for printing. Good tip. There's a smaller samy's store in Pasadena, but for this I think I'd go to the one in LA as it's much bigger.
Terry, looking at the sizes of the jpg and tif scanned images, the pixel dimensions on both of them is 903x638. The jpg is 587 KB and the tif is 3.29 MB. I must not have used a high enough scan dpi when I scanned them, right, CPK and disconnekt? I think before going to Samy's I will try one more scan, using the higher dpi. I did (and will) use the full negative strip and the plastic film holder which came with the scanner, so it was properly placed and presumably with the proper distance above the glass. As for matting, I'm afraid I haven't done that for any of my prints. After four photo safaris to Africa (and another one coming up next June, HUZZAH!!!!), I have so many African wildlife prints all over my house, that I just framed them without matting. I'm actually running out of room to hang them. I think I'll have to start rotating after the next trip. I guess I'm getting closer to being a "semi-pro" on the shooting side, but not so much on the display side
So...will try to rescan and let you all know how it works, and if it still doesn't give me clear edges I'll take a jaunt over to Samy's. If you could see the color in the original print, you would love it. If a re-scan works I'll post the results. The original scan is so faded in comparison. In the original, the blue of the sky blends very gradually into a hot yellow/orange at the horizon, with the tree, etc. stark against the sky. It was a truly beautiful sight in person, and I hope I can restore it from the old faded negative. I'll give another try. Thanks so much for your input, all of you.
Much appreciated,
Mary
