Originally posted by LensBeginner Significant DR to capture here... you did a pretty good job with the exposure, avoiding a blown sky...
Or better, you would have done a pretty good job if this was a RAW image...
Next time, base iso (plenty of light so no worry), ETTR (the highlights in the clouds will probably be at the far right) and just open up the shadows in LR.
You get lotsa detail and next to no noise (provided you did everything correctly.
That's how I would have done it, anyway, my 2c... ;-)
At least in my base-iso raw images of subjects like this, I always have had to give up something - more on an older body than a newer one, but still something, and I always compromise on the shadows, to keep some detail in the highlights. There certainly isn't "next to no noise" when I try to recover some detail from shadows as deep as these, although how much you're left with in the end with may depend somewhat on the sophistication of your noise reduction process. There can also be something lost at the end when you ultimately translate the image into a format that may be less capable of dealing with extreme dynamic range than raw.
