Originally posted by Nick Siebers Thanks everybody! Good stuff so far. My test prints were with some old HP photo paper I had around; I'll try some better stuff when I feel more confident. It sounds like that makes a difference. And adding a bit of saturation before printing, just like pre-printing sharpening, makes sense. I'm not sure about which color space to use, mostly I look at the shots on my computer, where sRGB looks better. Is it possible to switch color space after the shot, if I decide to print one? Doesn't seem like that would help, only further limit the gamut, but I don't know. And should I print from my RAW file after editing it, before I convert/save it, for the higher bits? Maybe convert to tif?
So many questions. :-)
I think the deal with the saturation is that the image on the monitor is direct light, whereas the print is reflected light. The monitor will always look more "luminous" because of that.
While I think that images shot in native Adobe RGB look marginally better on a pigment printer (I worked for years with the big Epsons with the K3 inks), they won't be so much different on an dye printer. There are monitors that can show nearly the full Adobe RGB gamut, but they are big bucks. Get a simple workflow (and write it down) that works pretty well for you and then make a bunch of prints. After a while you'll sense what, if anything, you'll want to change. You can use either sRGB or Adobe RGB. Like you said, the sRGB looks better on the screen, converting it to Adobe RGB won't make a difference, not so the other way around.
I think the Pro-100 is a great way to get into printing. The printer can be had for $50-$100 new, add $400 for ink and paper and you will end up with hundreds of prints and an greatly expanded knowledge of photography—all for about the price of a single photo class or seminar.
The Pro-100 does use ink on start-up, try to batch your works so you aren't printing just one or two per session. I've had mine for a year and a half and have never had a clogged head, so the head-cleaning on start-up is worth it.
Don't be tempted by aftermarket inks, they're nothing but trouble.
