It would really help if you could describe your workflow in Aperture in more detail. There is nothing much, if anything, in Aperture that can't be done in other applications. But (a big BUT) is that how those things are done matters. For example, the selecting and stacking options in Aperture and Lr are so similar as to cause confusion and distress, even though at the end of the day you can more or less accomplish the same thing in each.
Also, users who have a managed library in Aperture as opposed to a referenced library will have more difficulty transitioning to another product. Look those terms up if they aren't familiar, because it's important: Lr ONLY does a referenced library. Many applications have to use some sort of import process to get stuff out of a managed Aperture library (like Lr) and that can be problematic. Look at Aperture Exporter; it's a bit of software that can make getting stuff out of a managed library MUCH more efficient and troublefree (note it's an EXPORTER, not an importer like Lr's tool). It might be a good time to reconsider whether you should be using a managed library at all, or indeed what you should do overall with your photo organization. For example, since many of the alternatives use referenced libraries/catalogs, it might be time to consider your filesystem's structure, where you put photos in the Finder. And whether keywording is a better way to go, or date-based folders, etc. You may have to do a lot of moving around anyway so it's a good opportunity to clean house.
In addition, it seems to me many didn't really need a tenth of what Aperture does. These days a photo BROWSER might be a better choice than a DAM like Lr or Aperture that is a parametric image editor, something that stores info about the photos. A browser is like the Finder, only optimized for photos. And it can be faster and easier to use. Download XnViewMP for a free example.
If you do want a non-destructive editor and do RAW, then the RAW conversion of the alternatives matter. Some, but not all, alternatives will have their own RAW conversion algorithms; Aperture/iPhoto/Photos all use the same Mac system-based RAW conversion. Lr uses the same conversion as Ps; Capture One has theirs, etc.
Check out the alternatives' educational materials and plugins too. Lr is far and away the king here; aside from all the free and paid lessons, most every school uses Adobe stuff. But some smaller developers may have enough, and it may actually be less difficult to learn. Again, depends on what workflow in Aperture you're coming from. Lr has some plugins that are unbelievably awesome, like most anything from Jeffrey Friedl or John Beardsworth. And that's just housekeeping stuff; most any image processor (Nik, DxO, Macphun, Topaz, OnOne, etc) is gonna produce Lr and Ps plugins. Not all produce plugins for other applications. And many standalone applications work great with Lr, and can even see into Lr catalogs for accessing images: stuff like HoudahSpot Geo for geotagging, PhotoSweeper, Snapselect, Fotomagico, etc.
And right now two of the best plugin developers have big sales going on: Macphun for their Creative Kit (awesome; better than Nik IMHO), and DxO (the best of all IMHO).
Finally, there's the issue of connectivity. Aperture and Apple obviously want you to subscribe to iCloud Photo Library, which is nice, but pricy. And very inflexible. Some folks can use an Aperture alternative in combo with Photos to make that work (Photos not being an Aperture alternative really). But there are other tools to accomplish getting your stuff out there. Lr has many more publishing options, especially if you use available plugins (like Friedl's). And Lr Mobile is very good, but it's chiefly a Lr-Mac OS TO iOS solution. Another very good alternative is Mylio, which is a synching system based on what are essentially watched folders, more like Dropbox without the cloud storage. So if you change one photo on one device its automagically changed on ALL devices. And like iCloud it can pass adjustments and edits around if you use Lr, and has some decent editing functions itself.
All the stuff I've mentioned (and there is much much more) has free demos. You should absolutely try before you buy; don't get anything that is only available in the MAS since you're stuck if you don't like it.
