Here are 2 examples of processing in SilkyPix Developer Studio Pro 6. The hand-held raw shot of an Australian Magpie was taken with a K-3 & Sigma 70-200/F2.8 II HSM. 1/400s, f/5.6, ISO400, 200mm FL.
In 100% zooms, I noticed blue-green colouration on the chest feathers. Initially I thought this might be moiré, (I had not switched on the AA-filter simulator in the K-3), but SP's Reduce Moiré option didn't remove it. I found under the NR controls that the Colour Distortion slider set to 78 removed enough of it to satisfy me. The 100% comparison below has the adjusted version on the left.
This colouration does not appear to be lens-specific. I get the same problem with the same subject with a DA* 60-250/F4. Perhaps it is related to the demosaicing method SP uses.
This Sigma lens showed significant Lateral Chromatic Aberration with this subject. Lat. CA is most obvious when looking near the edges of the image. Here's a 400% processing comparison of a claw near the bottom.
And a 200% comparison of the beak near the top of the frame.
After developing the raw as a 16-bit TIFF, I did some further processing in PaintShop Pro X7:
- Mild Clarity increase
- Mild Local Tone Mapping
- Topaz Labs Detail 3 sharpening plugin
- After resizing, USM 0.6, 30%
Finally here's the result and a 100% crop of the chest feathers.
Dan.
