Originally posted by BarryE Emalvick, that approach offers up some distinct possibilities. I'll investigate what you've written. Thanks for taking the time ...
But you can essentially save XMP metadata (all that IPTC, exif stuff) to files using Bridge without having to use Lr's database. And smart objects save image adjustment info. Basically both are a way of saving in files what Lr saves in a database. Lr does save some stuff in the database that CANNOT be saved in files, like collection membership, publishing status, flags, etc. But much of the that info can be saved in other ways in the files.
Basically, without more info about what you need that you don't have, there isn't a reason to introduce Lr into your workflow.
Originally posted by Hawkeye17 Hi- Newby here- is the Pentax Browser and Lab3 software sufficient if I can get a copy or does apple photo currently using for point and shoot or picasa have enough editing and cataloguing? Cant afford LR or PS. I downloaded Gimp but am way over my head on this stuff. I do have a penchant for getting nice shots so who knows where it will lead- it has been suggested I shoot in RAW first. I just got a K10D body and am rustling a lens before I can fire it up. I live in a scenic place so I expect the Pentax can do it justice, soon as I get an adapter for the old smc 50mm . cheers and thanks for the tips
Software is here:
Software Downloads : Support & Service | RICOH IMAGING
Picasa is being discontinued; don't use that.
Apple Photos can work fine. I'm not a fan, but hey, it's free (although the iCloud Photo Library gets rather expensive if you use that). It's probably preferable to Pentax software.
If you need to sync, try Mylio. The free version lets you sync I think 3 devices. It stores edit and adjustment info in XMP files, and is compatible with Lr if you ever decide to go that route. Another option is Xnview MP; free, although a bit of a clunky interface.
