Originally posted by UserAccessDenied I have access to a HP DesignJet 4500ps at work. Boss said I can print for free, no worries.
We have a very nice matte photo paper as well I can print on.
I read the specs online and it says it's best used for technical applications and production work (we use it for geospatial applications)
Would this suffice for my photography?
Most will likely be A2 or A3 sizing...
Another thing I'm confused about:
Is there a preferred workflow for printing?
DNG to LR > Edit > Export to Jpeg/Tiff/PNG? > Print?
Any help would be appreciated.
Here is an example photo I would like to print (A3)
I have experience with HP DesignJet 5500ps (A six color plotter - yes, it's an inkjet printer, but everybody at work calls the large format printers 'plotters'). They were designed for roll-paper only, in large volumes, at poster sizes (A1 and bigger). For large poster-sized prints, they produce acceptable quality, since you tend to look at the prints from a greater distance. Mine is dye-ink only, and can have some significant color fading issues on certain paper types (non-photo matte papers, especially). My prints are for temporary use, so image permanence is not a concern.
When using photo satin/luster papers, the printer can put down lots of ink. Mine has a heater plate under the paper output, and I set it to Max. when printing on photo paper. Don't let the printed front surface of the paper come into contact with itself until it is absolutely dry - it will fuse together, ruining the print.
Do all your color/contrast adjustments in PS or LR - try to avoid any of the adjustments available in the printer driver. This can cause major slowdowns in the speed of the print. I often export as JPG or PDF depending on what I need, and notice no quality difference compared to TIFF (which is much, much larger file size).
I recommend you experiment with the printer, to get a feel for what large format printing is like, and how printing large affects your image's 'look'.
Summary: Good for large poster-sized prints, with acceptable quality. For exhibition/sale of prints, where quality and longevity matters most, I would use the pigment Epson K3+ printers instead. For smaller paper sizes (A2 or smaller), desktop printers offer much more flexibility in paper sizes, paper types, and paper handling options.
