Originally posted by photoptimist Curvature reduces the "field of view" of the reflections off the screen
If you are getting excessive reflections from your screen then there are workspace design issues that need to be addressed. Facing a window when working with a PC, or having your back to a window is probably the worst design choices for any workspace. Though this depends upon the design of the room, the positioning of the windows and how much light they bring in from the sun or artificial sources.
Originally posted by reeftool Personally, I think the curved screen is more of a gimmick feature than anything else.
I'm inclined to agree with you. I have seen some arguments that curved screens address the issue of colour accuracy and provide improved screen illumination in the corners with larger screens, but IMO the best solution to this if it is so critical: it to simply sit back further. Most IPS panels have very good colour accuracy even when viewed off-axis, and as for corner illumination - if you cheap out on your monitor you should expect uniformity to be compromised : more expensive monitors generally have fewer issues with uniformity.
