Originally posted by johnmflores Has a lot of potential to run Adobe Creative Cloud.
Sure it has
potential, however two ram slots is awfully limiting*, one hard drive is equally limiting. The number of USB ports is also concern, however there are internal USB headers. If you do upgrade it the high component density means there is a high probability that cooling will be an issue. The Intel video card isn't a huge issue for image editing** and the system seems to have a weak built in sound card***
Small form factor PCs have been around for decades and the limitations of their hardware expansion has always prevented me from buying into a system.
*RAM is one of the most important things with image processing systems, the CPU doesn't matter so much as de-mosaicing RGGB isn't really all that computationally demanding.
** if you are into gaming, or 4K video production it will be.
*** I like to listen to music while I work, and I'm admittedly a bit of an audio quality nut. I never use the built in soundcards I use a USB DAC hooked up to a Klipsch 5.1 speaker system.
