As far as I can make out using Google translate on an interview posted 3/22/2016 on DC Watch motion correction is incorporated into the K3ii and cannot be turned off. It seems both cameras (K-1 and K3ii) use basically the same algorithms but it works better on the K-1. Perhaps due to the sensor. Perhaps it will be in the next firmware update for the K3ii. My impression is that it is already a feature of the K3ii. Mind once again this interview was published in March around the time of CP+.
Perhaps one of our Japanese reading members can provide a better translation.
http://dc.watch.impress.co.jp/docs/news/interview_dcm/20160322_748845.html
Via Google translate (note: realistic-resolution = Pixel Shift):
Quote: The --K-1 of realistic-resolution system, but joined a feature called motion correction, please tell us about this process.
Uehara: In K-1, but may be used as they are of the on / off motion compensation, in fact, have also moving object correction is incorporated in the K-3 II realistic-resolution system, always moving object correction it turned on.
--K-3 II faster-moving, such as automobile subject, but I have noticed is that in which they are processed not in multiple, motion correction of the K-1 had thought it became more powerful.
It can be photographed K-1 realistic Resolution System with motion compensation on, not is stronger in a moving scene than K-3 II that?
Uehara: only sentence in which the number of pixels is increased, but those of the K-1 might fine movement has increased more discrimination can case impression of the subject, the basically the same motion correction algorithm K-3 II also K-1 is adopted it has.
- Such as the scene in which the cloud is flowing, or is that slow the movement of the subject is that the still weak?
Uehara: clouds of flow Toka trees of buzz is a difficult subject for detecting a good movement, we recognize that it just weak realistic-resolution system.
- So, K-1 of a moving object correction off, Will what circumstances has been prepared taking into consideration?
Uehara: because motion compensation by comparing the image of the four shots, which part is moving, or not moving, for it has to determine, what is really at rest and there is a very fine picture I also I'm certain it would determine that the wrong move in.
And a discriminated area moving, replaced with images taken first sheet, since the super-resolution processing is not performed, it becomes the same described as normal shooting. For this reason, such as the still life shooting in the studio, consider the case, such as to shoot a subject that does not work absolutely, I was to be able to shoot with the moving object correction off.
By the way, if you shoot with a realistic-resolution system, so much noise of attitude is less than the normal shooting, the sentence, the person who was taken at a fast shutter speed to increase the sensitivity, with less subject blur I think that a clear image is obtained.
- When you shoot at realistic-resolution system, the line is very thin, I think you better also tonality?
Uehara: normal in the sensor of the Bayer arrangement, because it does not only obtained RGB any one color of information in a single pixel, but has created the color and brightness information that is not enough to estimate the pixel interpolation, realistic Resolution When taken with systems, since all RGB color and luminance information in one pixel is obtained, it is not necessary to interpolation processing, it leads to a final sharpness by going to correct the color reproduction of fine place you.
- In the normal shooting and realistic-resolution system, I think I'm naturally also different over how the sharpness?
Uehara: different. In the case of the realistic-resolution system, since the sputtering and the two points are separated, undershoot, when the sharpness processing, such as put the overshoot, because that would impair the dense detail depiction, large edge portion as much as possible to, you do not put the border, we are emphasizing process so as to reverse to highlight the texture of the parts of the face.
- By using a lens with a magnification chromatic aberration, what happens when you shoot in the realistic-resolution system?
Uehara: If a lens corresponds to a lens correction, but it is output by correcting the chromatic aberration of magnification, more magnification chromatic aberration and it is non-compliant lenses It stands out and clearly (laughs).
- Is there something about the low-pass selector?
Numako: sensor is even in the full-size, K-3 / K-3 II with exactly the same effect of the APS-C can be obtained.
