Originally posted by UserAccessDenied What browser are you using?
In Chrome the image is dynamically rendered to resize as the window is sized... So no horizontal scrolling should ever be present.
Page formatting and comments look okay on my screen, and I'm on a macbook 13"
Also tested this thread on my work computer with a 1080 monitor without any horizontal scrolling.
Regardless, I'll remove the photo.
I didn't mean to cause peeve!
---------- Post added 05-16-16 at 10:44 PM ----------
Hey, here's the dropbox link as promised!
https://www.dropbox.com/sh/qak6n6l4nki75kr/AACgzLI_K3hxIPnEqcRlUResa?dl=0
Subject: Fingerling potatoes in a wooden bowl.
There are 4 images total.
3093 - DNG non-pixel shift - 31 MB
3094 - DNG pixel shift - 115.4 MB
3095 - JPG pixel shift - 14.9 MB
3096 - JPG non-pixel shift - 10.2 MB
Let us all know what kind of workflow you test out.
And if you need more samples just let me know!
Cheers!
Logan
Hi Logan, many thanks for taking the effort. What I saw:
# I inputted then via Bridge, directly into ACR (latest CC version 9.5.1.595)
# I could see straight away at 100% the difference between 3095 and 3096 jpegs, the pixel shifted version being sharper.
# BUT ... I could see NO difference between the two DNG files. I abused the files by extreme adjustments, but I could not distinguish any difference.
I assume the four files are straight out of the camera. Correct ?
From this I'm concluding that the pixel shift processing in camera works well to produce jpegs, BUT pixel shifted DNGs outputted from camera and then inputted directly in ACR are
not able to be processed as a pixel shifted file in ACR. I'm guessing ACR is just using one of the embedded 4 RAW files and not in any way managing to merge the data. If this is true then the DNGs need to put through ('Pentax') software that understands pixel shift. However, I believe from what has been said here that DCU does NOT output RAW/DNG files, only jpeg or tiff.
*** So do I conclude correctly that from the K-3ii it is
not possible to process RAW/DNG pixel shifted images in Adobe ACR ?????? That you are stuck using jpeg files and therefore have lost all the advantages of RAW processing possibilities. If so then then the pixel shift technology is (currently) not anything more than an interesting idea to me :-(. Hopefully, there's a way to get a pixel shifted file into ACR as a RAW/DNG file to be processed as any other RAW.
Many thanks, Logan. Your efforts have helped with my understanding a little more, but left me feeling somewhat deflated. I had hoped to be able to take extra high resolution shots of artworks with the pixel shift technology that I could then process carefully in ACR to ensure I achieve a near-perfect colour match (ie in colour managed RAW), before being able to enlarge these extra high res shots more satisfactorily than I can without the pixel shift technology. Seems it may be a no-starter at present.
Hopefully, I'm wrong and/or have missed something and there's a way round this ... Any ideas, anyone ?
