06-21-2016, 05:25 PM   #1
Seeking advice on Raw Therapee correction settings for radioactive Takumar yellowing
Just what it says in the title - if anyone out there is shooting a yellowed Takumar that they haven't treated yet, and you've found settings that would help correct for this, what are they?
It also occurred to me that I might make the correction under hue or white balance correction in-camera (K-5, current firmware); any suggestions as to whether this might work and how?
06-21-2016, 05:55 PM   #2
Bruce Clark's Avatar
To set white balance manually you need to use a white card. P185 of the manual describes the process in some detail. I would suggest that this process would work but only in those particular light conditions. I doubt that using a setting to compensate for the lens would work in all conditions.
06-22-2016, 12:42 PM   #3
emalvick's Avatar
I would think a gray card and adjusting white balance would be adequate. If you are looking for something automatic, I suspect you won't find it too easy unless you experiment to see if you can use the same temperature correction regardless of where you are in terms of light temperature.
07-04-2016, 04:33 PM   #4
Wellll.... here we go. In search of something fun to do, I threw the radioactive Tak onto the K-5 and started playing around with the presets. I discovered that if I set it to "muted", all the yellow colour cast is gone. Vanished. Disappeared. And this even gets written into the raw files.
Mine not to reason why. Of course the lens is hellishly soft, useless for crisp detail wide open, but it does produce a rather interesting "seventies colour film" effect that has its own charm. I may yet Single with it at some stage, once I've finished my trip down the 30/20mm spiral over the next couple of months.
correction, photography, photoshop, settings, takumar
Raw Therapee Wavelets graeme83 Digital Processing, Software, and Printing 2 07-22-2015 05:54 PM
Desperately seeking advice on a SLEW of Pentax 67 issues paperc Pentax Medium Format 7 06-30-2015 07:15 PM
Raw Therapee last bulid for Linux 64-bit Oxygenum Digital Processing, Software, and Printing 10 04-24-2015 03:28 AM
Seeking guidance on K-3 Auto ISO and Program Line settings IchabodCrane Pentax K-3 3 09-06-2014 04:14 PM
Seeking advice on lenses for KR Cptn_Goodvibes Pentax SLR Lens Discussion 8 12-05-2011 03:44 PM
All times are GMT -7. The time now is 08:35 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
