Originally posted by racingsnake when i get home and load that image into LR5, the histogram there most of the time is cramped all the way to the left.
Originally posted by Na Horuk Basically, the histogram in the camera is slightly inaccurate. It is not of the raw data itself, but of the developed jpeg. This means if you have things like vignetting correction, shadow correction enabled, if you have a certain type of jpeg mode (bright, landscape, film reversal, etc.) and even WB will have effects on the histogram. The raw data itself will have a different histogram (usually slightly more to the left, but can even have different peaks)
Secondly, once you import the raw file, it may immediately get edited - depending on your settings of the software. This edit can cause further changes in the histogram, making it look even more different from the one in-camera.
Assuming the above quotes are true and accurate it raises a question for me:
It seems to me that whatever else the sensor "knows" at the instant of exposure it does know which pixels are going to be over or under saturated for any given exposure and this sensor behavior is independent of whatever else may or may not be happening further down the line.
Question: Why does it take rocket science to report this relatively simple sensor behavior directly back to the photographer out in the field in real time?
As a further refinement, when shooting RAW, the Tog should have the option of, in addition to the usual jpg a small thumbnail of the histogram taken directly off of the sensor at the instant of exposure.
I really don't get it, or perhaps, I'm just being too simple-minded.
