Originally posted by Oakland Rob I think I see now. Since "autotone" will adjust differently for each photo it analyzes, you want those values, but just say x amount less exposure on each. Use this plugin then:
Relative adjustment
I had the same problem with C1; I got C1 Express just cuz I liked what it was doing with some of my RAW. But they dumped it soon after I bought it. Both C1 and Lr can reference the same file. C1 is kinda in competition with Adobe, but that might explain why they use their own way of doing things. Other Lr competitors like Mylio accommodate Lr and Ps since they are such standards. Maybe your observation is a reason to avoid C1; it is for me.
Thanks for the link... and yes that is essentially what I want to do.
As I said, I haven't really tried C1 (last I tried was probably version 7). Part of the reason I'm using DxO a lot more is that I don't need the relative adjustments, or rather, DxO's auto-adjustments are right where I'd want them. LR tends to over-brighten things; i.e. I always feel it adjusts the exposure and whites too high.
So, if I were to ever go to C1, and I probably won't, I'd expect the auto-adjustments to be at least as good as DxO's.
---------- Post added 10-10-2016 at 07:50 AM ----------
Originally posted by Class A C1 can import LR catalogues.
I tried it once and it didn't work in my case. Perhaps my catalogue format was too old (LR 3.6). In principle, it should work, though with most basic adjustments being supported.
If you want to export an image from LR to be used in C1, why don't you just export to the TIFF format for instance?
At least C1 has the "session" workflow next to the "catalogue" workflow that should make using an image in C1 a more lightweight process than doing a full import.
Overall, though, I don't see LR and C1 being used in conjunction. Yes, C1 has much better colour editing and more local adjustment choices, but if you are leaving LR anyway then why not to something like PS that has better retouching support than C1 and LR combined?
The fact that I would need a whole new catalog is why I am not trying C1. In reality, I catalog my photos with IMatch as it has better features for my workflow. My only dislike is that software like LR and C1 make it difficult to just process a handful of photos. C1 does have a leg up with its Sessions, but the sessions do make a bit of a mess with the creation of sub-folders and sidecar files that I wasn't able to wrap my head around. Part of the reason I test and now use DxO is that (1) they made a plug-in to get photos from LR, which was great when I started transitioning and (2) it is really easy to work straight to DxO from IMatch.
As far as I can see DxO is also competing with LR, but they recognize that (1) people are already invested in LR for a catalog feature and (2) that the best way to grab customers is to make it easy for people to get at the software from their competitor. My comment was really that C1 could make it easy on LR users to ease them in. I can see where they wouldn't also, but from a business standpoint, they might be missing out. Generally, people are conservative about things like this and are going to be hesitant to jump from one software to another for cataloging and processing.
As for why people might use LR and C1, it would strictly be that they have a working catalog in LR but want something different for post-processing. It isn't so much that they might edit in LR and then in C1. Again, having to shift a whole catalog to another software just to use a RAW developer is part of the problem with the models used by LR and C1. All catalog software has its differences, and I doubt that any is going to make a clean conversion that will just work.
I suppose the cleanest thing would be to work with Bridge/ACR/and PhotoShop, but for my use, the cleanest thing is going to be to leave LR completely and likely never to try C1. I'll be curious to see how On1's software works as it seems to have a lot of features that might make it like the Bridge/ACR/Photoshop route since it has no real catalog. I guess I'll see.
