Originally posted by Tony Belding uhhh. . . I think I may, at some time when I was setting up Lightroom, have told it where to keep its library folder on my computer. Ever since then it has been copying imported files into that folder and organizing them with sub-folders. I guess that must be "Auto Import".
And I haven't figured out how to make Darktable do that. That's my complaint.
Although, I think it's moot now. I've come to my senses, and I laughed, and laughed, and I dismissed all foolish notions of switching from Mac to Linux. It would be a huge amount of expense and time and work for dubious benefits.
Darktable doesn't organize files in the same way Lightroom does. The copying from camera onto your computer you have to do yourself. So, if you want a library folder, the workflow is
1. Create folder on computer
2. Put folder of pictures into this library folder. I usually name them with a date like 2016-02-15-description.
3. Import folder with Darktable
Darktable probably will never support auto-cataloguing file management by default, as the developers have stated that this is a design choice. Alternatively you can use Rapid Photo downloader as mentioned earlier in this thread. If this is the only thing keeping you from trying out Darktable I suggest you try again. However, if there are other things like this that will just annoy you obviously you should just stick with what works.
