Originally posted by UncleVanya I'm always a bit mystified by the hold the camera upside down advice. I never do. Go look at bright sun beam in your house. You will see dust floating in the air currents. This stuff is so light that down has almost no meaning in the time you will be cleaning. The air movement is far far stronger than gravity vs air resistance. I clean my camera in whatever orientation is easiest. And my sensor gets clean. Just stop believing in magic. Dust doesn't fall quickly and holding the camera upside down is only making things harder.
Ah that is one way to get your point across, insult others with a different PoV and experience.
Oh the other hand, I see what you mean yet it is a reason I do what I do. There are more than the 3 particles in the room, that are currently trying to be removed from the sensor. As you mentioned, there is a ton of it in the room.. unless you're in an industrial clean room. Dust does fall quickly, and depending on the amount circulating in the room, it can become a nuisance. However, in my experience holding the camera at an angle down or directly above me has worked better.
Do what you think is best, but I will do (and recommend) what I find best too.
