Originally posted by FAPARAGEATM I could not find the Digital filter effects options / selections,
The best you will get is this item [under the Custom Image tab] of PDCU:
However it is not representative of the large number of filter options available in camera.
The in-built help for v5.6.2 describes some of the options a bit more [see below]
but they don't seem to work. For example, the 'Filters' icon only becomes active in the 'Monochrome' setting, but it doesn't seem to do stuff like extract the colour 'Red' from an image, like the in-camera filter would, for example, even if you select Red in the filter.
And although the Help file says that the 'Filters' icon should become active if you select 'Muted' or 'Bleach Bypass' as the Custom Image option, the filter icon fails to appear if you do.
Originally posted by FAPARAGEATM 2) How do I post produce or edit a photo with Digital Filter effect embedded (without losing the Digital Filter effects?)
Save the image as a TIFF or JPEG in-camera, then post-process as needed.
If you save in RAW (DNG or PEF), you may be able to see the effects in PDCU 5, but it doesn't
seem as if you will be able to edit them. This is a rather silly limitation of Pentax DCU
