Originally posted by BigMackCam OK... further to that, is there any way I can see the crop width, height and offset to ensure I get an APS-C sized crop that is dead centre?
Cropping is doing it. Once you make sure you have cropped correctly that is that.
You do the cropping and save it as preset.
Originally posted by BigMackCam Again, I should have been more specific. My full-frame gear is Sony with 24Mp sensors... only my APS-C gear is Pentax
However, I'll take a look at that thread. The idea will be the same - I just need to create a PNG file with the APS-C frame showing, right?
The overlay does not care of you use a barbiecam
. It just displays information on top of your image. As long as your barbiecam is 3:2 format you will see the x1,5 crop of it outlined on top of it.
The file you get from that thread does inlcude a psd file with overlay, which you can easily turn into PNG. The PNG does not need to be the same resolution as any other image as you can scale it manually.
Once you tried it you'll understand.
