Originally posted by Sagala Where do you read this: ''noise removal software depends on reading the image's histogram''?
It was an interesting find actually. I will have to try and it find it but this seems to be a common concept for noise removal software as I saw it mentioned in more than one reference.
They say that because these noise distributions have specific function curves, to identify what type of noise distribution your image has, you simply look at the histrogram. The histrogram of the noise should look like one of these distribution curves:
Source: http://www.slideshare.net/kalyanacharjya/image-restoration-40589017
Once you can identify the distribution type, you are then one step closer to removing noise successfully by knowing what algorithm to work with.
I, on the other hand, am actually interested in noise generation for images - thus my original question. It would make sense that several types of noises are present in any photographic image. I suppose I was asking more about the noise type (distribution) to create real-world noise. For instance, I have also read that uniform noise rarely occurs in nature and is highly unreaslistic whereas gaussian noise is a much more natural type of noise.
@lithedreamer; Are you sure that both color noise AND luma noise are found together? In the example you posted, it seems like luma noise is created (and left over) after your software attempted to reduce the color noise. It would seem it tried to normalize the colors thereby leaving their luminance intensities which show up as luma noise... no? You brought up a very interesting point - I never considered that you can have color noise AND luma noise together so I would like to know the answer to this as well.
Thanks for your replies guys - please keep them coming. Any insight into other characteristics of photographic image noise is worth mentioning here.
EDIT: Here is where I found that discussion regarding identifying noise type by looking at the histogram:
Link
-Rich
