Show Printable Version 11 Likes Search this Thread
03-30-2017, 07:51 AM   #31
QuoteOriginally posted by blackest Quote
It's not too bad when you write to a tag exiftool makes a copy and labels the original, original.
Dx0 can only be as complicated as good as the exif information is.
E.g I set a 55mm km lens as a fa 50mm it needed the max aperture and focal length to match and the LensID and a valid fnumber
you can do this in realtime too
e.g the picture is open in dx0 and you change a value it refreshes if it stays gray it doesnt have a matching module if it goes red it has a number of matches and if it is green it matched.
Heh. Clever, good work! More work than I wanna do, but good to know. I have often wondered why DxO doesn't at least allow manual selection of lens profiles (like where you know the lens is simply re-branded but otherwise the same). Nice to know that if necessary one could work around that.
03-31-2017, 10:30 AM   #32
QuoteOriginally posted by Oakland Rob Quote
It works for canon too
I have an old hanimex 135mm f2.8 M42.
exiftool -FNumber="11"
exiftool -LensType="Canon EF 135mm f/2.8 soft" _V1H3533.CR2
exiftool -MinFocalLength="135" _V1H3533.CR2
exiftool -MaxFocalLength="135" _V1H3533.CR2
exiftool -AEMaxAperture2="2.8" _V1H3533.CR2
This is what I did but
exiftool -LensType="Canon EF 135mm f/2.8 soft" -MinFocalLength="135" -MaxFocalLength="135" -MaxFocalLength="135" -FNumber="11" _V1H3533.CR2
Would work.
exiftool -LensType="Canon EF 135mm f/2.8 soft" -MinFocalLength="135" -MaxFocalLength="135" -MaxFocalLength="135" .
would have done the whole session
Fnumber I would be better to leave alone. with the chipped adapter i think you can dial it in.
working out the used aperture is a tad tricky
How i think it works is the camera measures the light coming through the lens and calculates an exposure.
green button metering stops down and calculates the difference in ev
and then calculates a difference in shutter speed.
I think the nominal max aperture is 1.2 to calculate a base shutter speed from. lets say its 1/180
stopping down results in a change in metered light lets say 2 EV so the shutter speed needs to be 1/45th
What we actually know is the ev measured at max aperture and the shutter speed used to take the photo.
The value for effective ev might be recorded as -3 but what we don't know is what evectiveEV was for the max aperture value it could be anything
03-31-2017, 12:31 PM   #33
Just an addendum:
With cameras like the K-x, you could also use [the late, great] PhotoMe to produce a JPEG showing a summary of the LV measured in each metering area:
The late great Photome, lives on and is very useful of the 16 metering segments in a k200d
1 is centre spot :12.6
2is centre edge :12.1
3 upper mid right :10.8
4 upper mid left :11.1
5 upper right : 11.0
6 upper left :12.2
7 mid right :10.9
8 mid left :12.9
9 right :11
10 left :12.8
11 lower mid right :13
12 lower mid left : 12.6
13 lower right :12.6
14 lower left :12.8
15 Top :11.4
16 Bottom :12.6
I am thinking that 1,2 are used for spot metering 12.6, 12.1
1,2 , 7,8 for centre weighted 10.9 12.9
all of them for matrix metering. (the rest).
1,2,7,8 = 48.5 total avg 12.125
EffectiveLv was recorded as 13.1
LV was 13.
and Light value ev100, for f8 and 1/125th iso 100 is EV13
next shot
Lightvalue 13.5 55mm 1/180th f8 aperture iso 100 (Exposure Calculator to Compare Any Two Camera Exposures) value is 13.5 which is nice
-2 exposure compensation
segments 1,2 7, 8 11.9, 11, 9.0 9.5 avg = 41.4/4 = 10.35
EffectiveLV 11.5
ho hum seems these are a series of bracketed shots so this one is underexposed 2 EV
Lightvalue 13 1/125 f8 iso 100
12.6 12.4 12.5 12.1 (12.4)
EffectiveEV =13 0 exposure compensation
next
exposure compensation -2
f8 1/500th (15EV)
Lightvalue 13
EffectiveLV 13
12.5 12.2 12.4 12.4 = 12.375
next
Exposure Compensation +2
f8 1/60th (EV12)
LightValue 10.6
EfectiveLV 13
12.6 12.4 12.5 12 = 49.5 = 12.375 ( just tried the -n option works out to 12.4)
Does any of this make any sense?
About the only thing i know for sure i had my camera set to bracket exposure 3 years ago
05-16-2019, 03:15 PM - 1 Like   #34
Camera Simulator, Exposure Calculator, Scene Light Value -49 to 69 Ev-Lv.
Huge work with exiftool on Pentax EXIF datas, congrats blackest !
... it has a Light Value in EV Calculated from the light...
Right, the Light Value at the end of EXIF datas is Calculated,
the formula : LightValue = Log˛ ( Aperture˛ * 100 / ( ExposureTime * ISO ) )
keeping ISO at 100, changes to : ExposureValue = Log˛ ( Aperture˛ / ExposureTime ) @ ISO 100
I built an utility SW 1st written in Pascal Language... in Delphi-Kylix around year 2k...
Now that every Browser supports the JavaScript Math.lib...
I just rewrote it in HTML JavaScript :
Please :
- don't change Ev-Step from 1/3 to 1/2 or vice versa...
- don't change back Ev-Step from 1/2 or from 1/3 to 1 Ev...
until I have time to fix the errors giving Non-Normalised Values !
Enjoy !
05-19-2019, 02:04 AM   #35
QuoteOriginally posted by geo444 Quote
Please :
Enjoy !
Its not pretty but its effective thank you.
05-20-2019, 01:33 PM   #36
Camera Simulator, Exposure Calculator, Light Value -49 to 69 Ev.
I'll work on its prettyness as soon as I finish with its effectiveness
the latest advances of the Camera Simulator in efficiency
Enjoy !
05-26-2019, 12:51 PM   #37
Enjoy !
How about combining it with a dof calculator ? Link the aperture for the exposure with the dof calculator
what do you think?
05-27-2019, 12:49 PM   #38
what do you think ?
Hi Blackest !
I'm sometimes thinking about it for a while now...
but for the Astro-Photo., I've not so many opportunities to regret not having it
A fast, lightweight, Universal Utility Software such as the Exposure Calculator would be a nice idea,
not a Huge Collection of Constants engraved inside the code like MasterDoF is :
Exposure Calculator would have needed 2 856 Constants
the Exposure Calculator is a ~20 years old story, starting with Pascal, then Delphi-Kylix...
Now, re-written in HTML-Java-Script, so it's able to run on Every System,
I need a little more time to build something in my head...
at night... during Looong Exposuuures......
05-28-2019, 12:23 PM   #39
Hi Blackest !
something like Free Depth of Field Calculator.
maybe
07-24-2019, 03:43 PM   #40
For HDR i wanted to find all photos that were take using exposure bracketing while the shake reduction is turned off.
I used "exiftool -json" in combination with "jq", to have a little more control over what exactly gets changed. Don't wanna touch the DNG's by accident.
Close darktable and digiKam
Install Requirements
Code:
 sudo apt install exiftool jq
Create a big JSON file with all EXIF data (adjust file pattern as needed)
Code:
 exiftool -json -g 20??/*/IMGP????.DNG > db.json
From the JSON tree select all files that match auto bracketing and disabled shake reduction. (jq is a query language for JSON data.)
Code:
 jq -r '.[] | select(.MakerNotes.ShakeReduction == "Off" and .EXIF.ExposureMode == "Auto bracket") | .SourceFile' db.json > filelist
Given that every DNG file has a existing XMP sidecar file, add a single keyword "forHDR" to allow filtering in digiKam/Darktable.
The XMP "subject" tag might not exists and should not already contain the keyword, to avoid duplicates.
Test the condition without adding the keyword.
Code:
 while read L; do exiftool "${L}.xmp" -if 'not defined $subject or not $subject =~ /forHDR/i' -filename ; done < filelist
WARNING: Add the keyword to all sidecar files
Code:
 while read L; do exiftool "${L}.xmp" -if 'not defined $subject or not $subject =~ /forHDR/i' -XMP-dc:Subject+=forHDR ; done < filelist
Start digiKam / Darktable to re-load the sidecar files.
09-30-2021, 12:08 PM   #41
angerdan's Avatar
An very interesting and techy Thread
Are there any news?
aperture, camera, column, compensation, exiftool, exposure, focus, k-mount, lens, light, lv, pentax lens, photography, photoshop, shutter, slr lens, tag, value
EXIFTool - AF Point in Focus bxf Pentax K-3 & K-3 II 13 05-27-2018 10:55 AM
ExifTool GUI Google Map interface is not working PDL Digital Processing, Software, and Printing 3 10-21-2015 02:25 PM
Defining Pentax-Specific Tags in Exiftool mblanc Digital Processing, Software, and Printing 3 02-23-2012 08:53 PM
Exiftool How to use Pontax Digital Processing, Software, and Printing 3 11-28-2011 12:08 PM
You can read K-x battery state via PhotoMe or Exiftool rawr Pentax DSLR Discussion 6 11-02-2009 06:38 PM
All times are GMT -7. The time now is 10:29 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
