Originally posted by newmikey Aha, now I get the point - I wasn't aware of that. But isn't the number and naming of the focuspoints (11 for "older" Pentax AF systems, 27 for newer) somehow mappable to the focuspoint layout in the viewfinder? With other words, wouldn't it be possible to take a physical layout of the focuspoints in the viewfinder and determine what the tag-names Top-left, Top Near-left, Top, Top Near-right etc. would correlate to?
I'm struggling to understand why the number of focuspoints in the makernote tags correlate so strongly to the SAFOX 11 or 27 focuspoints if they weren't directly related. But I'm not technical or sftware-savy enough to challenge anyone on that besides my simple logic which may turn out terribly faulty - apologies for that.
Sure, there is a direct correlation between the naming and the positions.
However, there's another important issue at play here: not all Pentax cameras spit out the same names in the metadata to indicate which points are selected/in-focus. For instance, the K-50 records names like "Center," "Upper-left," etc., but the K-1 stores numbers 1-33 to indicate each point. Obviously, this needs to be accounted for since each camera has its own metadata quirks and I have found that the documentation is often inconsistent. This is exactly I was asking for the RAW files -- to figure out what each camera records in the metadata over a variety of situations.
Quote: I'm struggling to understand why the number of focuspoints in the makernote tags correlate so strongly to the SAFOX 11 or 27 focuspoints if they weren't directly related. But I'm not technical or sftware-savy enough to challenge anyone on that besides my simple logic which may turn out terribly faulty - apologies for that.
This actually brings up an interesting point. Are there really only three Pentax autofocus systems with 11, 27, and 33 points? I already have the mapping for the 11 point system that I made for the K-50. I'll need to scale it to accommodate the pixel dimensions of the different cameras (the K-50 is 16 MP), but that's trivial. We also already have the 33 point map for the K-1. That means that we're only missing the map for the 27 point system.
---------- Post added 04-12-17 at 12:59 AM ----------
Originally posted by beholder3 Which I would consider a behavior which makes a lot of sense. In that case you did configure the camera to have its autofocusing system passive unless you press the backside "AF" button. You briefly pressed it earlier, but in the moment of shutter release and image file storage you did not, so the AF system was not active then and probably there was no AF sensor readout in that moment just because of that. Seems logical that nothing is stored then, because exif could only store the last/historical data, not any current.
Imagine you would use that exact same usage pattern to frame a portrait and focus on the eye in the center of the frame and afterwards pan the camera to the left and release the shutter. Basically you are asking the metadata to record that the center AF point had something in focus where the image might show you that at the point in time of capture the AF point is on the far away background which definitely is not in focus.
Anyone being unhappy about this way of filling metadata would be very right in my book.
In total agreement! A subtle point indeed. Unfortunately for our purpose, I do think that it is quite common to press AF2 once to achieve focus then take a series of photos without necessarily refocusing.
Anyway, this is just one a few specific scenarios that would have limited success with the plugin. Thanks a lot for clarifying this behavior.
