Originally posted by following.eric better with or without paper simulation checked? a few things I have read have shown both options.
If you do not check paper simulation then you are not going to see a real sembelance of how the paper will print your data, therefore you are losing the advantages of soft proofing.
With these items checked it is quite possible that you will want/need to adjust such things as density, contrast and hue and sat.
Quote: last question. I got the Spyderexpress today but it does not have the ambient light adjustment (couldnt afford next model up). So what would be a suggested kind of neutral way to adjust it. I usually have window ambient light of either soft or harsh and I would say because of that I generally have my screen at maximum brightness. Which apparently I shouldnt have with editing.
suggestions to try and get consisten? like try and only edit in a controlled envirnment with low ambient light and half monitor brightness? then calibrate for that and always try and edit in similar settings?
The ambient light auto adjustment is an absolute waste of time. You definitely do not want your calibration software altering your luminence levels when it senses changes!
Ideally you should be looking at controlling your editing environment ambient light to maintain a constant level. No one can really give you any figures for the luminance setting other than to suggest that it may fall somewhere between 100 - 150 cd/m2 for most domestic situations. The correct value is one where you get a print to screen match. You should not be thinking in terms of half or full monitor brightness but rather let the calibration software set that for you (by your adjustment to match the target value). Rough and ready starting point for monitor luminance try 120 cd/m2 - you will need to adjust more precicely once you have some real prints to compare
One important point that always seems to be missed is the fact that you need to have your print correctly illuminated and once again under ideal conditions for the print white to match screen white.
Please have a look at the link I sent you to Lagom and examine how the screen should look, taking note of how different ambient light levels affect how you percieve values particularly shadow and highlights.
