Originally posted by RAART I do not know your location but if you are close to the border then here in Canada is cheaper to get it...
Canada:
BenQ SW2700PT Photography 27" QHD 2560x1440 IPS Monitor, 5ms(GTG), DCR 20,000,000:1 (1000:1), 99% Adobe RGB, Hardware Calibration, Shading Hood, Palette Master - Newegg.ca
USA:
BenQ SW2700PT Photography 27" QHD 2560x1440 IPS Monitor, 5ms(GTG), DCR 20,000,000:1 (1000:1), 99% Adobe RGB, Hardware Calibration, Shading Hood, Palette Master-Newegg.com
Usually the Intel 4000 supports the resolution of 1440px display via display port. Should support also via HDMI but not sure about it and i7 should have not a problem with that. You have more then enough processing power just RAM memory and it should be good.
From two you mentioned I prefer the PD2700Q but both of them do not support hardware calibration and if you are planing to add calibration device then you have to think about it.
---------- Post added 08-14-17 at 03:24 PM ----------
Sorry my mistake... It is cheaper in US to get it.
That BenQ PD2700Q could do... but I just checked spec on my graphics card on my specific Intel DH77EB motherboard, and the manual contradicts itself when it says it tops out at 1080, but then goes on to give the max tech spec of each port. That is probably theoretical of the port industry standard max? Prolly a safe bet I'll need a new card?
"1.3.1.1.1 Intel® High Definition (Intel® HD) Graphics
The Intel HD graphics controller features the following:
High-Definition content at up to 1080p resolution
but then goes on to say:
The DVI-I port supports both digital and analog DVI displays. The maximum
supported resolution is 1900 x 1200 (WUXGA). The DVI port is compliant with the
DVI 1.0 specification. DVI analog output can also be converted to VGA using a DVIVGA
converter.
The HDMI port supports standard, enhanced, or high definition video, plus multichannel
digital audio on a single cable. It is compatible with all ATSC and DVB HDTV
standards and supports eight full range channels at 24-bit/96 kHz audio of lossless
audio formats such as Dolby* TrueHD or DTS* HD Master Audio. The maximum
1920 x 1200 (WUXGA).
DisplayPort is a digital communication interface that utilizes differential signaling to
achieve a high bandwidth bus interface designed to support connections between PCs
and monitors, projectors, and TV displays. DisplayPort is suitable for display
connections between consumer electronics devices such as high definition optical disc
players, set top boxes, and TV displays. DisplayPort output can also be converted to
HDMI using a DisplayPort-HDMI converter. The DisplayPort interface supports the 1.1a
specification.
DisplayPort’s maximum supported display resolution is 2560 x 1600 at 60 Hz refresh
with a 16:10 aspect ratio (WQXGA).
