08-31-2017, 11:51 AM   #1
screwdriver222's Avatar
Paint Shop Pro file size limitations
I have been trying to open a very large DNG file using PSP. Its 6 images taken with a K-1 stitched together in LR6 to form a panorama. PSP won' open it. However the same 6 images stitched together using Microsoft ICE to produce an equally large file but a TIFF image can be opened.Their tech confirmed the problem and have a copy of the DNG file. They escalated it to the next level'. The versions I have used are PSP X9 and PSP 2018.
The latest news is and I quote from their email "Sorry, but please note that PaintShop Pro can only open file s up to 20,000 pixels. This is most likely the reason why your file cannot be opened."
It does not explain why it works with a TIFF file and 20,000 pixels seems ridiculously low. K-1 is 36 megapixels. what do you think, should I give up or get back to them again.
Jeff
08-31-2017, 12:06 PM   #2
Probably won't work because it's a .dng file out of LR. Didn't know you could save to .dng
---------- Post added 08-31-17 at 02:09 PM ----------
PS. IIRC there's also a max file size, 120MB (?). You'll have to go to the PSP forum for a correct answer on that.
08-31-2017, 12:21 PM   #3
LensBeginner's Avatar
Maybe they meant 20.000 pixels linear resolution:
20k * 20k = 400MP total, obviously less if aspect ratio is not square
08-31-2017, 01:05 PM   #4
Otis Memorial Pentaxian
QuoteOriginally posted by LensBeginner Quote
I believe that is the case. I also suspect that the Adobe-generated DNG may also be at issue. DNG is not a universal RAW type in that generating source may influence tool compatibility. A good example might be a PEF converted to DNG by Adobe's DNG conversion tool or at import into Lightroom. That file is unreadable by the Pentax Digital Camera Utility (PDCU) software. Apparently the Adobe-generated files contain proprietary elements.
09-01-2017, 12:25 PM   #5
I replied to their email querying their 20 000 pixel figure, you guys could be right about it being 20k X 20k. I have also sent them the same panorama but as a TIFF image created by Microsoft ICE and will see what they say. It could well be the Adobe DNG file type
Jeff
dng, images, k-1, paint shop, photography, photoshop, pixels, psp, tiff
Paint shop Pro hjoseph7 Digital Processing, Software, and Printing 11 11-17-2015 12:42 AM
Paint Shop Pro: 50% off ($49.99) Adam Pentax Price Watch 14 07-03-2014 08:51 PM
Paint Shop Pro users - what version is your favorite? ChopperCharles Digital Processing, Software, and Printing 7 11-10-2013 08:47 PM
Corel Paint Shop Pro Photo X2 not showing my RAW files Bokeh Digital Processing, Software, and Printing 9 05-14-2008 07:57 PM
K10D RAW File Support AT LAST in latest Corel® Paint Shop Pro® Photo X2 ! Confused Pentax DSLR Discussion 32 10-26-2007 09:58 PM
All times are GMT -7. The time now is 05:52 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
