Originally posted by BigMackCam As part of my gradual research and planning to move away from Adobe, I've downloaded the ON1 Photo Raw 2018 beta. So far, I really like what I see - there are some things I don't like so much (like the luminance noise reduction, and the sharpening masking, both of which are extremely heavy-handed compared to Lightroom), but mostly it seems very polished indeed.
One thing I've been unable to find yet is any way to remove "impulse noise" (such as stuck pixels). I shoot with several older cameras that don't have pixel mapping, and over the years they've picked up a few stuck pixels. Lightroom removes these automatically at import, while Corel AfterShot Pro 3 (and even RawTherapee) provide a selectable option for this... but I can't find the same functionality anywhere in Photo Raw. I know I could create layer to mask specific pixels, but I'd have to do that for each camera, and make alterations as and when new stuck pixels appear.
Does Photo Raw support this functionality? If not, it's kind of a deal-breaker for me - so I'd rather know now, before I invest too much time learning the software.
Thanks in advance
G'Day Mike,
Stuck Pixels
I forgot about the import benefit of dealing with stuck pixels that LR has so as suggested I'd ask On1 about it. As On1 is not doing a catalogue import like LR it probably doesn't exist as something to turn on through an options/set up panel. If they add this as an auto tool it would probably need to work as the file is loaded when you look at the full size image in Browse or when you select the image to go into Develop/FX/Layers etc. To do so on import would make this stage as slow as LR imports and I'd hope they wouldn't go down that path.
The advice on this already provided is what I'd recommend too, especially as the Beta version will change a fair bit over the next 12 months with improvements that could be on a similar scale as that which you're looking for (ie I wouldn't rule it out as an update to 2018 if enough people want it). The updates to the 2017 version initially focused on bug fixing but after that added some big changes to the program for the better. An example of this is the inclusion of camera and lens profiles in the Develop module, a big modification that came about 5 months after the release of the 2017 version. So as suggested, if you choose to park the program and move on it would be great if you could provide feedback on the Beta.
If you're a real good sport it would be great if you could also go to their website and go to Learn/On1 Photo RAW Project at this link:
Ideas – ON1, Inc. This is where new capability suggestions are submitted by users, so adding a recommendation for removing stuck pixels as an auto feature could be included here and hopefully supported by other users. Indeed, it might already have been suggested in which case you could add your voice to the recommendation. BTW, this is where the request for Pentax pixel shift support is sitting and I'd hope you'd be okay with adding support for that too.
Noise
I initially picked up LR2 because of it's lauded NR. It was one of the benefits of that platform, though by LR6 other programs were reporting as improvements over LR noise reduction. I didn't try these other programs and as I was using On1 as an LR plug-in my main NR experience has always been via Adobe. Since earlier this year I've parked LR so all NR has been via On1. It used to be in a separate package in the develop and FX modules but they added NR as an option in the initial Develop module tools which, I assume, is where you're applying it.
I've found this NR tool somewhat limiting and I when I do use it I use the Alt key when masking to try and target the areas I want NR to be applied (FYI a lot of the LR keyboard shortcuts are the same for On1). I then further manage noise by only adding dynamic contrast and sharpening to those areas needing it and avoiding dark shadows/skies etc where they will only increase the noise. This requires more work but has generated some good results. However, if you are applying NR like you would in LR you may not be seeing the complete picture with how On1 can work.
If you forgo both NR and sharpening in the Develop module try going into FX and adding it there. I recommend that as this is the part of the program where the masking tools are much more advanced and capable, and judging by the videos I've seen on the 2018 version even more so than what I'm used to. Doing NR in FX will enable you to more selectively target areas of your image for NR. This will give you better control than anything LR is doing.
Sharpening
The sharpen module in Develop for Photo RAW 2017 is not applied by default and requires a fairly high level of input to see it working. On the other hand the masking slider for sharpening is very heavy handed so typically I"m masking at around 1 only so there is some sharpening effect. I'm not a big fan on global sharpening though and even with masking I tend to prefer to mask in the FX module as I can target areas to sharpen better using the masking tools. Annoyingly the default sharpening is for printing so I select 'screen' and then do adjustments from there.
Don't forget too that there is a 'detail' option in local adjustments in both Develop and FX modules. This is another way of targeting the adding of detail and apparent sharpness with greater control of where it's applied.
Time for coffee
Apologies for the novel mate, it's Saturday morning and it's raining outside so I kept banging on a bit. I like the shortfalls you've identified and know if these were included it would be a much better program so hopefully they're working on it already. From my experience with using On1 the less than stellar NR/sharpening sliders will improve. I know that the slider length in 2018 is made longer to improve their functionality so this is an aspect being improved already. Anyhoo, I hope the program makes your shortlist as I've found the recent versions of On1 to contain very good tools that work differently to LR as it gives you much more control on your adjustments. And of course there's plenty of other things it does that LR can't so hopefully you'll take advantage of the 30 day free trial and suss out what else it can do for your workflow.
Good luck with finding the right solution for you Mike.
Tas
