Originally posted by Craigbob I've been experimenting with On1 too.
For me there are two deal breakers that are keeping me from using it full time insted of Lightroom.
The 1st, is that it doesn't handle pixel shift images. It just takes one image from teh envelope and works on that one. Worse there are no plans for them to support it.
The 2nd is the general instability of the program. It takes a long time to load a single non pixel shifted image and the program ferequently locks up doing so.
Until they get those two items fixed (The second one is urgent to me) it's a non starter. I may wind up using it in hybrid mode and transfer images there from Lightroom. though I hate the thought of converting to Tiff first.
If you already have LR why don't you just use On1 as an add-on? You can create a PSD, this will give you Layers if you want and you get the benefit of FX masking tools and PSD Layers will be intact if you also work in PS. It also means you can use Resize to export making use of the genuine fractals algorithms if you want to enlarge an image. Of course if you don't want to run two programs then none of those suggestions will help.
One thing many of us have found is the way On1 works compared to LR. LR takes a lot of time at the import stage. This is where LR is way slower than On1. The flip side to this is, as all the background framework/cataloguing is completed at the start it is quicker to work on an image within LR Develop etc. Everyone coming from LR identifies this but often they may miss linking that the trade off for speed in LR PP is the slow import at the start.
Another thing that many of us have found with On1 is how it works on the system you own whether that be Apple or Windows. It is less forgiving and it is worthwhile investing a bit of time setting up On1 to make the most out of your system. I find the minimum system recommendations from On1 ironic as technically the program may run on those machines but I don't think it would be much good. Of course that's an assumption as my system is at a higher spec. Disappointingly though I still have problems, but there are patterns to this and maybe this is worth trying before you write off On1 completely.
I have a lot of images, most on an attached NAS (>500, 000 images) and more than a gig on an internal drive. My system is about 5 years old and runs Win 7 with 32GB of RAM and 6GB of VRAM. So I have a lot of images but more than enough memory but the age of my system is a problem and soon I'll be doing the first OS refresh it's had in about four years. The aim is to fix some problems with the OS and hopefully improve the way On1 works for me. An OS refresh is a pretty significant maintenance routine so I don't suggest you must do one yourself for On1 to work, but I wanted you to understand my context and what I'm seeing with On1 on my system.
The point to make out of all of this relates to the number of images you have on your system and the size of the batches of new images you're loading. For that latter one are you returning home and importing 100 images or 1000?
Nobody at On1 Tech Support has confirmed this as I haven't asked, but I think On1 does a bit of image file management work in the background. So you load 100 new images, start sorting and processing and all the while you're doing this On1 is doing the type of LR import stuff (less cataloguing) on the rest of your images to make it more efficient during PP once it's done. Because of this I have regularly left On1 up and just sitting there in the background whilst I do other things. I think this has helped but I might be wrong as it still stops responding from time to time. It is however more stable than in the past.
So that's my experience with some conjecture thrown in. I came from LR6 as I wasn't interested in doing a subscription. Of course when you look at Adobe's rates per year and compare an annual On1 update there's no real difference other than the ownership of On1, it's portability without the internet and you choose how often you update. I recommend considering the above and seeing if any of it helps before you throw On1 into the bin as there are some features it has that goes way beyond LR capabilities as it sits more at a level of half LR and half PS. But unlike the Adobe offerings the masking options and the control you have over adjustments in FX is on a par or better than PS. IMHO, YMMV etc.
Tas
