Originally posted by derelict Problem is, I cannot find them and cannot figure out how to gain access to the catalog.
Anyone know a way around this? Is it possible for me to remove the catalog? Maybe alter it? Or, better yet, on a Windows machine, tell me where the hell this catalog is?
If you have only one Catalog, it opens when you open Lightroom. That's how you gain access to it. To find where it is located, open LR. Click on Edit>Preferences. Under the General tab the location of the Default Catalog will be listed. I do not recommend that you attempt to edit it in some way other than through normal LR usage.
If you know the name of the files, you should be able to search either in your operating system or within LR to find their location. In LR you can do this in the Library Module. In the left column under Catalog, highlight the line that says "All Photographs". In Grid mode, at the top of the screen should be three search criteria. Click on "Text". Then in the first box that appears next to the word Text, select "Filename", fill in the name of the file in the second box, and voilą, you should see your image. Repeat as needed, but also note where in your directory structure the files are located.
