Originally posted by rdenney I spent two solid hours during a layover in Newark yesterday reading about On1 and could not find the answer to whether it will do unsharp masking in 16 bits. I could not find any reasonable listing of the cameras it supports. I could not find out if it supports the ProPhoto color space. I did find out that it has color-managed printer preview.
G'day mate, I can help you answer these specific questions.
The list of cameras supported can be found here:
ON1 Photo RAW 2017.7 and 2018.1 - Compatible File Types and Supported Cameras ? ON1 Support This page also identifies file must be 8 bit or 16 bit.
So far as your other questions go, under the 'Edit' menu you can set file preferences, for example I have On1 set to PSD, Pro Photo, 16 Bit and 300PPI. This preference setting is specified as:
These options determine how photos will be saved when you edit them in Resize or an external editor. A copy of the original is always made in this format.
Note: When you send a photo to Layers it always saves the results in the layered Photoshop PSD format with Adobe RGB 1998 color space. If your original is not a PSD a copy will be made.
Sharpening can be done in a couple of different ways with On1. The first is the detail panel in the Develop module. Personally I rarely use this for other than NR though even then I don't always use NR globally which is how this sharpening/NR option works. For what you seek sharpening should be done in the FX module. This has significantly more control options including unsharp maks.
In FX there are 18 preset sharpening choices in a drop down menu, each of which can be adjusted to suit your personal preference using sliders for amount, controlling of halos and protection for shadows, highlights and/or skin tones. The sharpening options include High Pass, Progressive and
Unsharp Mask. Further control options include an eyedropper selection tool or 12 options to choose for selectively applying sharpening based on colour channels and tone. There's also the same blending options available as those in Photoshop as well as selective application using the masking options which includes luminosity masking.
I think On1 is an option worthy of further consideration though I do recommend you review the system requirements to ensure your computer will support the program.
Tas
