04-15-2018, 07:49 PM   #1
Luminar 2018 loads .dng's dull and flat
Does any one else use luminar? I loved Luminar to process my .nef nikon photos but when when I load photos from my new Pentax k1ii they look flat and require more editing. Is this normal or what settings should I change.
04-15-2018, 08:17 PM   #2
Otis Memorial Pentaxian
QuoteOriginally posted by jtstgeorge Quote
It may well be normal. How is it with PEF or example K-1 (v1) DNG from someplace like Imaging Resource (LINK)
04-15-2018, 08:28 PM   #3
One question...what are your "custom image" settings? Press ▶ (right arrow) on the 4-way controller to see the current setting. If it is dull like the one in Luminar, what you are seeing is likely the preview JPEG packaged with the RAW data in the DNG. Some programs default to the JPEG when they are unable to render the RAW.
04-16-2018, 06:11 AM   #4
Resident fiddler
LensBeginner's Avatar
Digital capture is linear, unedited RAW files appear very dark, dull and flat, if seen without first applying a tone curve.
Most editors apply some sort of default profile, so you see the RAW similar to a regular OoC jpeg.
Probably Luminar has no default profile for your camera and just shows RAW data?
Or you have a flat in-camera jpeg profile like Steve said, and you're just looking at the integrated preview.
04-16-2018, 11:08 AM   #5
clackers's Avatar
QuoteOriginally posted by LensBeginner Quote
To even see a picture on the monitor, the software must apply some kind of profile with a tone curve.
04-16-2018, 11:15 AM   #6
Resident fiddler
Yeah but if it's y = x then...
04-16-2018, 01:13 PM   #7
I'm currently using Lightroom and evaluating Luminar as an alternative and might consider to switch once their asset manager is ready. No real difference between them in picture quality when loading DNG files from my K-3 II. Looks every bit like jpegs from a "normal" setting.
I'm using a Mac, could there be a difference if you use Windows?
04-16-2018, 06:11 PM   #8
Hello from a fellow Pentaxian using Luminar. I just put up a post about creating some videos for Skylum Software for the Japanese market so you can check out my wife and I using and editing pics.
I'm no software engineer, just a guy pressing a shutter button, but I think that with the latest version you can select how it views the RAW files with a profile selector. From what I've heard their should be a digital asset manager coming this year which will be awesome.
Chris
04-16-2018, 07:35 PM   #9
OK I've got lots to learn. I had it set to auto (factory default) I've only had the camera for three day. So I steped outside and took 4 test shots. one in auto, one in neutral, one in vivid, and one in landscape, then opened each in luminar to see what happened. And that was the problem. Luminar and I like the neutral one best for a starting point.
---------- Post added 04-16-18 at 08:47 PM ----------
Thanks all for the help. I feel much better now. However, I haven't had a chance to get out and shoot the things I wanted the pentax for. But at least now I will be able to edit them
On the other hand can Luminar handle the super resulution files?
auto, default, jpeg, luminar, luminar 2018 loads, luminar by macphun, photography, photos, photoshop
Luminar Photo Editing csa Digital Processing, Software, and Printing 34 03-02-2018 07:52 PM
Luminar 2018 for Mac & PC now available for pre-order (Lightroom alternative) RAART Digital Processing, Software, and Printing 1 11-04-2017 04:58 AM
Luminar by Macphun - new photo editor pepperberry farm Digital Processing, Software, and Printing 8 11-17-2016 10:40 PM
Anyone tried the DNG Flat Field Plug-in Docrwm Digital Processing, Software, and Printing 4 05-13-2013 04:39 PM
All times are GMT -7. The time now is 08:54 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
