Originally posted by twilhelm What I do is drag and drop the folders from my camera to the folder I want it in, which for me is by year. I'll then use DT for adding tags. I know this isn't exactly what we use to do with Lightroom, but I've found it works in a way I've gotten my head around.
Originally posted by pentaxfall I use Geegie for browsing through SD card, then multi-select the ones that I care and MOVE them to a target folder. I manually create the target folder when I am stepping through Move-dialog box.
Coming to tagging, you may be already aware that DT gives the option of tagging at the time of importing.
Additionally you can install Sqlite client and look at the TABLE created by DT. You can see how meta data gets stored as rows and columns. I think this insight may help in organizing the data.
Originally posted by Lord Lucan I use Gwenview for photo management, and viewing thumbnails and full screen. It copes with DNG and PEF files.
I'm not sure what you are asking about regarding downloading. Is it a problem? I put the SD card in a USB card reader, mount it, and drag the files across from within my file manager, which is Dolphin. Same as I would copy any other files from one directory or device to another.
Originally posted by danielblues I think
Rapid Photo Downloader will do what you need, it does one thing very well.
I use the program above for importing to a 2Sort/Camera Exif Name/ddmmyyyy directory, then geeqie to sort/delete photos.
Originally posted by cfraz I use Rapid Photo Downloader too. It can create and name your file directories per your specs and file copy is as fast as hardware allows. I don't think it has tagging capability. I use DarkTable for tagging - ok but not as good as Digikam.
Thanks for all the info, folks
I guess I should have been a wee bit more specific...
Downloading
I typically transfer photos from the SDHC card via my PC's internal card reader. What I'm looking to do (ideally) is transfer them into directories named to my specification and rename them at the same time. Of course, I could simply copy the files into a temp area, then carry out the renaming myself and copy them into directories I create manually, but if there's a way of automating the task, I'd prefer it.
Photo management
Here, I'm looking to tag photos, find / sort / group / view photos by tags and - importantly - certain EXIF data elements such as camera, lens, ISO etc. I need to view thumbnails of JPG, TIFF and RAW files (DNG, PEF, ARW and potentially others) and be able to open them for full-screen viewing. The ability to the zoom into 100% reproduction would be nice, but it's not essential. Also, the ability to create resized copies for web reproduction would be very handy - but again, this isn't essential, as I can do that within Darktable and/or GIMP.
For both downloading and photo management, I can do most of what I need manually, but it makes for a pretty clunky workflow. Looking further at Rapid Photo Downloader, I believe it'll do what I need. For photo management, I'm not sure yet... the ability to use EXIF in searches is important to me...
UPDATE: Looking at the various tools, I'm thinking digiKam might be what I'm looking for. Firstly, it has quite flexible import capabilities - not as comprehensive as Rapid Photo Downloader, but probably flexible enough for me. In terms of photo management, it seems to do pretty much everything. And the nice bonus is, it provides built-in conversion from native RAW formats to DNG, meaning I won't need to use Adobe DNG Converter under WINE to convert ARW files from my Sony gear (I shoot DNG with my Pentax cameras already)...
