Spyder calibrators have been said to have worse inter-instrument agreement than those by x-rite. This is problematic as it defies the point of calibration if every device "sees" a monitor slightly differently.
The Colormunki Display appears to be a very good device but x-rite's best colorimeter is the i1Display Pro.
Note that colorimeters are relatively cheap and great for measuring dark tones but may have trouble with certain background light types and/or require profiles to work optimally with various display panel types. The i1Display Pro is special in that it stores its filter characteristics internally and allows software to interrogate this data.
The most flexible solution is a spectrophotometer like the x-rite i1Photo Pro2 or the ColorMunki Photo which can also calibrate printers or can be used to create emulation targets for non-standard displays such as iPads. Spectrophotometers aren't great with dark tones, though, hence one really needs both a spectrophotometer and a colorimeter (to calibrate the latter with the former)!
N.B., x-rite has the most idiotic naming scheme in the industry. It seems designed to purposefully disguise capabilities and confuse customers. It trumps even Sony's brain-dead mount renaming scheme.
Originally posted by pschlute I now use Color Navigator software which comes with my Eizo monitor.
Do you like the Color Navigator software? Any tips?
Which Eizo model have you got?
I'm thinking about getting one. I've seen one in real life and the smoothness of tonal graduations was absolutely gorgeous.
