I put this in Digital processing since it involves fiddling with PP, but it could have gone in General Photography or Photographic Technique as well.
Some days ago I discovered a way to shoot RAW with my smartphone, which isn't officially suppporting this function.
My Redmi Note 3 Pro has a S5k3p3 Samsung Isocell sensor, which is ok for a smartphone, but I always felt (and opinion on the internet and - more importantly - facts support this theory) that it's hindered by a less-than-ideal NR and processing.
By using FreeDcam I managed to get 10bit DNG files, that I processed on my PC, and the results speak for themselves (sorry for the amount of dust, but it's actually good to see how fine detail ends up).
In this picture it's not all that evident, but there's always lots of uncorrected chrominance noise in the straight-out-of-camera JPEGs, while luminance noise is overcorrected to the point that the whole image becomes a mushy mess. WB is often off by quite a margin.
I've experimented with settings and can say that you need a heavy vignetting correction (Quantity 100, Midpoint 0) and an unusual Daylight setting (Temperature 4100 K, Tint 14).
Other than that, some fiddling with the HSL panel is also required, but it's worth it, especially when you can leverage a superior DR (and this juicier example sure deserves all the DR it can get!):
As you can see shooting RAW is an effective remedy against the default washed-out look and the low DR of default jpegs, which often have a bad handling of wide DR scenes (either marked underexposure or clipped highlight), and using the exposure compensation simply isn't enough.
Hope you find this as interesting as I did.
