Originally posted by PenPusher Yes I could not see that much difference, I'll check the HDR slider thank you for that.
I figured that it would be quite good for Pentax because of the connection.
I had noticed the Japanglish, its not too bad.
Thank you.
I have used Silkypix for many years and am now using Silkypix Developer Studio Pro 7.
it is a raw converter with a lot of depth. There is a reasonable learning curve, but you can click on the ? icons and it brings up the relevant part of the manual very quickly. There are many presets so you can save a number of settings and very quickly batch process dozens of pictures. One of the things I like is if I change a lot of settings to get the first image of a set of pictures correct, you can simply use copy/paste command to apply those settings to the rest.
Remember this is a raw converter, not a cataloguing program. The HDR slider mentioned above is extremely useful.
Why not give it a try for free?
