Originally posted by Excalibor Some of you mentioned that you changed the demosaicing algorithm and took the automatic sharpening away...
Where in the config can I change these things?
The demosaic tool is in the "basic group", here:
... while the sharpen tool is in the "correction group", here:
Originally posted by Excalibor I have had quite satisfactory results sliminating noise and haze with Darktable, by using denoise and also by playing with the color channels, but the proposed solutions really look like an improvement... I don't usually mind luma noise, I might even enhance it and switch to black&white; plus my K-3 has a very nice noise, if that make sense: but chroma noise is definitely a nuisanse, and the loss of sharp edges is very annoying, specially on high ISO wildlife pictures, which usually need some added cropping (robins are really small!!!).
The beauty of the Equalizer tool is that for colour and luminance noise reduction, you can taylor the size of details within your image that it applies too, and the level of effect on each-sized detail. As I mentioned previously, it takes a little experimentation and practice, but it's worth it. Start with the "denoise chroma" preset in Equalizer, and adjust it to suit, adjusting the "mix" up or down to increase or decrease the level of effect.
