09-19-2008, 02:20 PM   #1
Michael Barker's Avatar
Expose to the right ... then what?
Let's say I exposed to the right to get the best use out of my sensor. What should I be doing in Photoshop CS2? Can someone give details, step by step?
09-19-2008, 02:32 PM   #2
just reduce the exposure to the desired level.
09-22-2008, 07:56 PM   #3
First things first....
New Adjustment Layer > Levels
Hold down the Alt key while you click your mouse on the right hand slider and it will show you all the clipped highlights.
Leave that layer for now and adjust your exposure slightly and keep checking that against the levels until the clipping dissapears.
Once that is done adjust the Levels layer to fine tune the exposure and your done.
Then.........
Ctrl + Click "RGB" in the channels palette.
This will slect the highlights which you have already fixed. You want to fix the shadows so then you click Select>Inverse.
This has now selected the shadows. You need to adjust the shadows to either lift them or deepen them. To do this you go....
New Adjustment Layer>Curves
Change the selection to Pigment/Ink.
Then move your cursor to the middle of the graph and you should get readings of 50 and 50. Click the centre of the graph when you get 50/50.
All you need to do from there is hold Alt and press the up or down arrove to either deepend or lighten the shadows.
Once that is sorted Layers>Flatten Image and then add your sharpening and Hue/Saturation and Contrast adjustments.
Hope this helped.
Nick
photography, photoshop, step
How to correctly expose birds Marc Langille Photography Articles 13 08-23-2010 07:24 AM
expose to the right? martez81 Photographic Technique 52 06-03-2009 12:58 PM
Expose to the Right: Proper use of the Histogram lastdodobird Photographic Technique 31 02-08-2009 09:24 PM
50mm prime vs Zoom, +1ev to expose the same? jeremy_c Photographic Technique 13 11-26-2008 10:08 PM
Expose ONLY when subject comes into focus. ukbluetooth Pentax DSLR Discussion 6 11-12-2007 08:54 PM
All times are GMT -7. The time now is 03:43 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
