Originally posted by TerryL Hello Folks,
I am trying to pick out an online printing service. So, I am wondering if the typical printing service can print at the resolution that I get from my K-1 and better lenses shooting in Raw?
Thank you,
Terry
Depends on your online printing service, their services and requirements for file submission, which should relate directly to the printer requirements.
For Canon/HP/Fuji you can expect a required standard resolution of 300 ppi and if native size above this 600 ppi will get the optimal quality assuming image is first rate and has the necessary IQ in the first place
Epson printers tend to use 360 and 720 ppi.
Whatever else happens in the print pipeline the print driver will resample your data to match its declared resolution 300/600 or 360/720. Using its own resampling algorithms which designed for speed, likely to be nearest neighbour.
You can use superior algorithms in applications such as PS and LR plus many others which may prove better in handling your image data
Typically in my experience many labs will use the lowest resolution when specifying file requirements. Nothing particularly wrong with this but if you have the native resolution and the subject matter contains strong lines diagonal and circular the higher resolutions may exhibit improvements and not leave IQ on the table.
