Originally posted by Jewelltrail I like using the Fast Stone software to process my Raws because I get good results and it is quick compared with Lightroom. However, the Fast Stone only processes Raws into 72dpi. There is no support for dpi in Fast Stone from what I can see.
I have to import the JPG I processed in Fast Stone into Lightroom and increase the DPI there. There must be a better way? Is there another version of FS which allows DPI adjustments? Any ideas?
There have been countless DPI threads here recently, but to simplify things a lot:
1. Your camera produces a file that has some fixed number of pixels.
2. Your camera knows
nothing about DPI because it doesn't know what size you want to print your image ( remember - DPI is dots per inch, so to calculate it you have to divide the number of pixels on one axis with the
length of paper in inches)
3. Now look at the image file your RAW converter produced - how many pixels does it have ? If you multiply the length and width in pixels do you get approximately the number of megapixels your camera has ? (for example if the image is 2000 x 3000 pixels you get 6 million pixels or 6MP)
4. If it is the same size as your cameras advertised megapixels (+- a few percent) then you
are getting all the data the camera has recorded !. It doesn't matter then if it has DPI 1 or DPI 72 or DPI 300 or DPI 10000.
If someone can give me an example of why a let's say 2000x3000 pixels image file(remember we are talking about a file here, not a printout ! ) at 300DPI is better than a 2000 x 3000 pixels image file at 10 DPI then please, humour me
DPI
does not exist before you print your file !
If some software says your RAW converter produced a file that has 72 DPI then your RAW converter just writes this number in the output file (most likely just to write something - as it really has no idea how large
you are going to print it.
It's really all about pixels, honestly, pixels are the only thing your digital camera can produce.
