01-20-2020, 02:48 AM   #136
JensE's Avatar
QuoteOriginally posted by deus ursus Quote
Yes. Pentax like base curve is turned on by default.Another of my friend also felt the difference. So we are planning to downgrade the DT to 2.x
My previously edited pictures, when loaded in 3.0, look OK. For the few pictures, which I edited using the basecurve approach in 3.0, everything was quick & smooth as well. I just loaded one example, and it matches the saturation & brigtness of the out-of-camera picture rather closely, without touching anything.
I'd suggest to look through the list of active modules and make sure that nothing unexpected is in there. I e.g. by mistake somehow changed my raw black/whitepoint default recently, which had a very dramatic effect.
01-23-2020, 03:07 AM - 1 Like   #137
cprobertson1's Avatar
Man, what a useful thread - thank you all very much! I think I'll spend tonight running the 3D printer, listening to music, and having a deeper look at darkroom (I've used it for practically all my photos, but thanks to this thread Im ready to take things to the next level!
01-31-2020, 01:17 AM - 1 Like   #138
Essential reading for all darktable users
One of the core darktable devs, Aurelien Pierre, has an article up on pixls.us that should be required reading for all darktable users. It gets into the theory behind the modules as well as recommendations for which modules we should be using and why:
PIXLS.US - Darktable 3:RGB or Lab? Which Modules? Help!
01-31-2020, 01:35 PM   #139
ChristianRock's Avatar
QuoteOriginally posted by jbinpg Quote
Can't read the whole thing now, but that is a very interesting article.
It sounds to me that a lot of modules need to be rewritten...
Edit: ok, some first impressions.
I don't do heavy editing but I like the basics to be right.
I like the direction that Darktable is going, but 3.0 still feels more like a beta product right now. As soon as I loaded a few too many modules, it seemed to crash my system. And it just seems quite a bit slower in general, especially when opening a different folder for editing - it takes forever to come up.
The results from the new filmicRGB seem very promising, and I finally played more with the color balance module. They all work fine, but I feel like I'm having to learn an all new software because the results are so different now, and a software that might still change quite a bit.
So, unless you need something specific from 3.0, I think I would stick with 2.7 for now. At least don't convert your database yet - try using it as a separate app first to see how you like it. But don't give up on Darktable, great things are coming up
01-31-2020, 08:58 PM   #140
I would not say v3.0 is in beta condition. Everything is working fine for me and I am riding the edge-of-your-pants dev code not the stable release. It is totally stable on my machines. What Aurelien is pointing out is that some of the existing modules could be rewritten so they support the devs' ideas of how a module should behave. Meanwhile, current code works well enough with some reservations. Can't wait until Contrast Equalizer is rewritten since I use this module a lot.
02-01-2020, 09:22 AM   #141
JensE's Avatar
QuoteOriginally posted by ChristianRock Quote
I spent ~30h by now with it. It regularly blackens using openCL when I use the local contrast module on high-contrast images. Worked around using the contrast equalizer. Other than that, it's been very stable for me, with only a few small glitches in usability. I exclusively used the filmicRGB workflow in 3.0 for a lot of landscapes, sometimes with a rearranged processing pipeline, e.g. graduated filter before the tone equalizer, and overall am very happy with the results. It was some learning curve, but well worth it. Very clean, artefact-free output even for significantly processed images to bring high scene dynamics into printable range.
02-04-2020, 11:04 AM   #142
Is anyone having any issues with 3.0 and the KP? When I import images now they have an odd desaturated look, almost like an Instagram filter. I can't quite figure out what the problem is... I'm shooting using DNG.
02-04-2020, 01:27 PM   #143
QuoteOriginally posted by selfnoise Quote
In page 9 someone else was complaining about this... must be a bug with some cameras?
I don't have that issue, but the settings for my K10D differ wildly from my K-S1. I edited some files from the K10D and wrote a preset. When I try to use that preset in the K-S1, the saturation and colors are completely off (and no white balance changes are involved). Something interesting is going on...
02-04-2020, 01:29 PM   #144
JensE's Avatar
I have to reset the 'raw black/white point' module to defaults after applying one of my styles. Maybe related.
02-04-2020, 02:09 PM   #145
QuoteOriginally posted by JensE Quote
What I do is set my black point and exposure before applying the style. My styles specifically don't contain white balance or exposure at all.
If black/white point is your only issue, you're not doing too bad...
02-04-2020, 02:27 PM   #146
JensE's Avatar
Just to make sure I'm understood: Related to @selfnoise's question, if for some reason the black level 0 to 3 in "raw black/white point" are off, just slightly for whatever reason, this can lead to a washed out look.
I normally don't touch the four raw black point (nor white point) values at all. They're part of the DNG metadata and determine how the channel values are scaled - not to be confused with choice of tonal range. This comes later in the processing pipeline, after demosaic, input color matrix etc., using filmicRGB in my case.
I use a "style" as a first step, because there is no out of the box set of modules applicable to a filmicRGB (instead of Base Curve) workflow defined. This way, some of the default modules are turned off, others turned on with neutral settings, because they (almost) always get used in my workflow.
02-05-2020, 10:14 PM   #147
Just a note that the latest v3.1.x dev code has changed the order of the modules in the processing pipeline. To me, it has improved the final image. Printing seems to be borked for the moment but that is something i don't use.
02-17-2020, 10:50 AM   #148
FYI
Today I opened my Flatpak installation of Darktable to convert a jpg into a rotated hard copy. For the first time in my intermittent recent openings, Flatpak pulled the 3.0.0 version instead of the 2.6.3 version. From this I conclude that a version 3 Flatpak configuration has finally been built and put into the Flatpak repository (or whatever it is called). It does convert some stuff, but the message wasn't too clear about what.
02-17-2020, 02:24 PM   #149
JensE's Avatar
Changing the order on-the-fly is one of the very useful new features in 3.0 - I'm using a non-default order most of the time. Most of the time I'm pulling Graduated Density to an earlier stage before the tone equalizer. G.D. is one of the modules, which the otherwise very useful article on pixls.us by Aurélien PIERRE and community doesn't discuss. I could use "exposure" with a mask instead (useful for more complex geometries anyway), but the interface of the dedicated module is quicker to adjust for simple cases.
03-06-2020, 11:27 AM   #150
The already mentioned above Aurélien Pierre has posted a survey on “how(…), for what and by whom” darktable is used, and the objective is “to help making design and development decisions with a little less guessing and assuming”.
One can access his post here: darktable user survey - darktable - discuss.pixls.us
And the survey can be accessed directly here: darktable user base survey
Best regards,
adrian, background, colour, darktable, film, flickr, jpegs, k1 mark ii, lightroom, mask, matrix, noise, page, pef, photography, photoshop, pictures, program, shot, software, space, stock, styles, tiff, vuescan
Denoise in Darktable is not as good as I hoped Tranzistors Digital Processing, Software, and Printing 16 08-12-2018 01:12 PM
RAW files. What should I use to develop them RawTherapee, Darktable or ......? jonthechippy Digital Processing, Software, and Printing 33 01-16-2018 02:26 PM
Darktable for windows - recommendation as LR replacement beholder3 Digital Processing, Software, and Printing 4 11-26-2017 12:48 AM
Question for Darktable (under Linux) users BigMackCam Digital Processing, Software, and Printing 10 11-05-2017 12:52 PM
Darktable with Pixel Shift ThatSummer Pentax K-1 & K-1 II 15 05-07-2017 01:08 AM
All times are GMT -7. The time now is 04:13 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
