04-07-2020, 06:33 AM   #166
ChristianRock's Avatar
I used to get very natural colors right out of the base curve set to the Pentax curve. The Leica curve was very very similar - just a tad less contrast. Filmic always took a bit more work but it was actually basically ok from the start, at least the colors wouldn't be way off.
Even in your example, after your base curve and initial adjustments, the maple leaves still look dry and the color is still quite a bit off. I think it would take a bit of work to get them looking right - something that I didn't have to do in previous versions.
04-07-2020, 07:53 AM   #167
Which is why you need to experiment with the modules to see what works for you. Then you make a preset which you can apply to an image automatically on import.
04-07-2020, 08:43 AM   #168
QuoteOriginally posted by jbinpg Quote
My experience is that what works on one image isn't going to necessarily work on another image when this much tweaking is required.
When you go around changing hues and things like that, it's quite different from just developing a base curve you like.
04-07-2020, 09:00 AM   #169
Riggomatic's Avatar
I have noticed that when I open .dng files in Linux, the base curve is set to preserve colors = none (drop down option under the curve), and when I open the same file in Windows10, the preserve colors = luminance.
The preserve color = luminance looks more muted, while the =none option is more vibrant.
I play more with the levels, than the base curve.If I understood the base curve more (more practice), I'd probably use that more.
I should be using my time off work, and deep diving into each slider that I play around with in Darktable.
04-07-2020, 01:39 PM - 1 Like   #170
QuoteOriginally posted by Riggomatic Quote
That actually helped a bit, Riggomatic.
With the preserve color = none, I am closer to where I want to be... but I'll have to redo all my styles since they're all starting with preserve colors=luminance...
(yes your comment made me reinstall 3.0.1...)
Edit: now after having edited a few pictures, all other modules seem to behave properly again, now that the "preserve color" setting was set back to none. I'm happy with DarkTable again
04-07-2020, 02:06 PM   #171
Riggomatic's Avatar
QuoteOriginally posted by ChristianRock Quote
Glad to have helped.
I'm also checking some of the presets on the curve: the Pentax Like vs the Pentax K-5 (my camera).
When I do the snap shot, and compare the images with the slider, the Pentax Like curve is brighter (with the preserve color = none)
I think I need my base curve set to Pentax Like with preserve color = none. That looks more like the .jpg from the camera to me.
04-07-2020, 03:01 PM   #172
Ok so after playing around with FilmicRGB a bit more, I'm definitely not going back to 2.6 There are a lot of good possibilities with this and it really is much better than anything I was able to achieve with the base curve, even after solving my color issues.
I'm glad you guys didn't let me give up
Edit: for some reason this looks brighter in Darktable but after exporting, it got darker... hmmm.
04-17-2020, 11:22 AM - 3 Likes   #173
Just wanted to say thank you to ChristianRock and Riggomatic as a lurker on this thread, but very much a DarkTable user.
I recently bought a K3-II to upgrade from a K30 and that switch coincided with my installation of 3.0.1. With the K3-II and 3.0.1 combination, my pictures were starting so greyish and dark in the darkroom that I was getting concerned about whether it was camera or software. I found a few modules that I hadn't had to use in earlier versions and was able to play around and get things looking okay, but the final images still came out a bit blueish. Lots of googling didn't give me nearly as much help as this thread. Now I guess I'm going to re-process a bunch of pictures.
Thanks all.
04-17-2020, 03:19 PM - 2 Likes   #174
New Darktable version (3.0.2) is out
This new version (an detailed information about what is new /corrected) can be obtain directly from GitHub: Release darktable 3.0.2 released · darktable-org/darktable · GitHub
Best regards,
05-08-2020, 07:43 PM - 1 Like   #175
Clarkey's Avatar
Just to say I'll be joining this coterie. I've been working on as pared down a setup on Darktable as I can get. Working on MX Linux for fun these days.
Enjoying the Equalizer a lot. Effortless with the GR as it is already so sharp.
Glade trees
by Aaron, on Flickr
05-08-2020, 11:01 PM   #176
GUB
GUB's Avatar
I have just done a build of MX Linux - been using it for a few months. But I miss Gnome3 too much and am probably going back to Ubuntu. What have you been using up to now Clarkey?
05-09-2020, 06:55 AM   #177
Clarkey's Avatar
QuoteOriginally posted by GUB Quote
Hi, Gub. I have MX on 3 devices in the house now. Windows on the way out as I am done with the spyware and update processes. I had a built of mint/cinnamon going for a while, but Deb based stuff seems to work for me and MX is a nice balance. I've not tried Manjaro yet. The only downside I have encountered is having to deal with CUPs for printing, which is a linux issue.
05-09-2020, 02:54 PM   #178
GUB
GUB's Avatar
QuoteOriginally posted by Clarkey Quote
Yeah I have a virtual XP guest that I use as a printing app for photos. Having said that the Ubuntu is now at least printing a text document.
Trying to define what I don't like about the MX linux. The applications directory is hard work but I think it is because I am not used to the MX names. And I really miss the gnome 3 ability with the displayed windows.
05-12-2020, 03:09 PM   #179
Clarkey's Avatar
For me, I am used to the windows structure of folders and the file manager is close enough. Maybe that's the issue - too close to Windows!
05-15-2020, 11:15 AM - 1 Like   #180
Clarkey's Avatar
Opeongo memories
by Aaron, on Flickr
adrian, background, colour, darktable, film, flickr, jpegs, k1 mark ii, lightroom, mask, noise, page, pef, photography, photoshop, pictures, program, shot, software, styles
Denoise in Darktable is not as good as I hoped Tranzistors Digital Processing, Software, and Printing 16 08-12-2018 01:12 PM
RAW files. What should I use to develop them RawTherapee, Darktable or ......? jonthechippy Digital Processing, Software, and Printing 33 01-16-2018 02:26 PM
Darktable for windows - recommendation as LR replacement beholder3 Digital Processing, Software, and Printing 4 11-26-2017 12:48 AM
Question for Darktable (under Linux) users BigMackCam Digital Processing, Software, and Printing 10 11-05-2017 12:52 PM
Darktable with Pixel Shift ThatSummer Pentax K-1 15 05-07-2017 01:08 AM
All times are GMT -7. The time now is 11:02 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
