Originally posted by Clarkey Also, my Olympus E-M1II seems to have disappeared from the lens fun database.
Assuming that you are on a BSD or Linux computer (due to your mention of "dual boot"): Did you try "lensfun-update-data"?
Please keep in mind that certain Linux distributions (eg. Ubuntu and derivates) may use "snap" or similar installation methods beside the native package management which can affect the installation of darktable and other software. Calm down, Ecky.
On my Linux installation (Garuda Linux, a fairly user friendly Arch Linux derivate) the E-M1II is in /usr/share/lensfun/version_1/mil-olympus.xml which was installed via the package manager, so no manual customisation. I just verified that the "lens correction" module works properly on a photograph taken with the E-M1II. But I have darktable 4.2.1 here, not 4.2 like you.
Lensfun has a suggestion for a workaround (just edit mil-olympus.xml):
Lensfun
Hope that helps.
Yesterday I tried to activate the "hot pixels" module for RAW files from my K-5IIm. darktable doesn't "recognise" neither a DNG nor a PEF as a RAW file and refuses the hot pixels correction.
The search on
discuss.pixls.us - Free Software Photography and
Issues · darktable-org/darktable · GitHub didn't help.
The closest match seems to be that one:
sRaws / DNG LinearRaws get assigned JPEG (non-raw) workflow · Issue #14558 · darktable-org/darktable · GitHub
Have you experienced such behaviour of darktable?
E.
