Originally posted by Riggomatic I just use the mouse scroll wheel on the sliders (example black level correction moves by .001). Hover the mouse over the one you want to adjust and scroll up/down. Hold down the CTRL key and use the mouse wheel on the sliders for a finer control (example black level correction moves by .0001)
reset the control by double clicking (left mouse button) on the slider (anywhere).
I noticed this works on the tone curve too, once you add a point. Holding down the CTRL key and scrolling with the mouse wheel takes forever BTW.
Thanks - using the ctlr achieves what I want - that single unit movement is needed with an exetremely underexposed image pulled up with the curves. Thanks but I will run with that drop down whisker box now I know it is there.
OK next thing -- I just opened DT now to experiment and for some strange reason the Tone curve, Base curve and the basic exposure modules were all open together! Never seen that before! How on earth can you make that happen - it is so convenient! I suppose I should be reading basic instructions somewhere - but then I am a male!
