Show Printable Version 140 Likes Search this Thread
09-30-2019, 08:04 PM   #91
GUB
GUB's Avatar
QuoteOriginally posted by ashurbanipal Quote
Don't overlook the ability to set your most-used modules as favorites; that way you can do most of your work in the first module group.
--Steve
Yes that looks like the only way to do it. I thought you could selectively place modules in each module group but, no, they go to their preassigned group.
So I have the star group with WB , Profile denoise, Exposure, Graduated Density, Base curve and Tone Curve all default opened. That covers 90% of my work.
10-21-2019, 02:22 AM - 1 Like   #92
New Darktable version (2.6.3) is out
This new version (an detailed information about what is new /corrected) can be obtain directly from GitHub: Release darktable 2.6.3 released · darktable-org/darktable · GitHub
11-06-2019, 07:21 AM   #93
Darktable 3.0 is out.
11-06-2019, 07:28 AM   #94
Darktable, rawtherapee, Siril, Gimp. Whatever we use for whatever we do Opensource and FSF FTW!
11-06-2019, 08:18 AM   #95
ChristianRock's Avatar
Very cool - 3.0 is a major rewrite - both UI and performance have been worked on.
I think I'll wait a bit though, to hear if it's stable enough. Apparently the DB is different so going from 2.6 to 3.0 is a one-way street.
11-06-2019, 08:35 AM   #96
JensE's Avatar
So far it's an RC, so you'd better test it on a separate DB and be willing to report bugs.
11-06-2019, 01:37 PM - 1 Like   #97
QuoteOriginally posted by krgroothuis Quote
Not correct!
What is out is the first release candidate of Darktable 3.0 - “darktable 3.0.0rc0”.
To get the full information about the new stuff (the new stuff is huge!) and access to the installation files for the several operating systems go to darktable 3.0.0rc0 released | darktable.
The final full 3.0 version should be available around Christmas – last year it was in the 24th of December.
Best regards,
11-17-2019, 11:13 AM   #98
mhoule418's Avatar
Just following that thread...
Thanks.
11-17-2019, 01:31 PM   #99
jlstrawman's Avatar
QuoteOriginally posted by ddharriman Quote
Not correct!
[darktable-user] darktable 3.0.0rc1 released
11-17-2019, 07:51 PM   #100
I have been checking out the latest code. The dt team have hit it out of the park with this release. Many may never get past the Basic Adjustments module. But if you need more, it is covered. I am getting my builds from here:
Install package graphics:darktable:master / darktable
Unfortunately, only linux builds there.
Jack
11-28-2019, 01:54 PM   #101
Even less than a month from the final release of Darktable 3.0 (if the timeline of last year’s is maintained), they keep on putting out new RC’s, being just out 3.0.0rc2.
This new version (an detailed information about what is new /corrected) can be obtain directly from GitHub: Release darktable 3.0.0rc2 released · darktable-org/darktable · GitHub
Best regards,
12-01-2019, 09:15 AM   #102
I find the new filmic RGB module quite difficult to use. For some scenes it's helpful with handling highlights but in my experience there's a bit to much back and forth between the tabs to get a good result. The tone equaliser is very intuitive and useful however.
12-01-2019, 04:54 PM - 1 Like   #103
If you have a chance to watch the developer, Aurelien Pierre's, youtube video on his new filmic rgb module, you will see that his intention is for a user to followup enabling and adjusting filmic rgb with his tone equalizer.module for optimum effect. I too struggled with the new module for a while but it has become my SOP now versus using a basecurve.
12-02-2019, 02:34 PM   #104
I'm not sure filmic could be standard in my workflow. I feel there are few to many assumptions built into the module. Its quite hard to do minor adjustments. Strangely filmic implementations work well for CGI work.
12-04-2019, 11:09 AM   #105
With filmic, I end up just using the default settings and if adjustments are needed I'll use other modules. I do most of my adjustments in Brightness, Contrast and Saturation, and in the Exposure module for setting a black point.
With time I want to dwell more into it, but I can't seem to be able to improve things much!
Sometimes I'll even double it up with a base curve which I know is a no-no - but it can add to the 3D effect of older manual lenses, I guess due to the layers of contrast handling. These lenses have lower contrast anyway, so the end result is usually pretty interesting.
adrian, background, colour, darktable, film, flickr, jpegs, k1 mark ii, lightroom, mask, matrix, noise, page, pef, photography, photoshop, pictures, program, shot, software, space, stock, styles, tiff, vuescan
Denoise in Darktable is not as good as I hoped Tranzistors Digital Processing, Software, and Printing 16 08-12-2018 01:12 PM
RAW files. What should I use to develop them RawTherapee, Darktable or ......? jonthechippy Digital Processing, Software, and Printing 33 01-16-2018 02:26 PM
Darktable for windows - recommendation as LR replacement beholder3 Digital Processing, Software, and Printing 4 11-26-2017 12:48 AM
Question for Darktable (under Linux) users BigMackCam Digital Processing, Software, and Printing 10 11-05-2017 12:52 PM
Darktable with Pixel Shift ThatSummer Pentax K-1 & K-1 II 15 05-07-2017 01:08 AM
All times are GMT -7. The time now is 12:04 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
