The magenta didn't work at all(5%), all else is fine!. Tried cleaning "power clean(big clean), started it again when i tried a small clean of print heads AFTER a nozzle print!, I was very insulted as the screen that said "information" didn't say what the printer was doing "In progress" but what is in progress(it was a power clean!!!. by the looks of ink used). Learned that its really not smart to use other than printer intended. I think, maybe if you don't buy the "precision" head of the 4760, other Ecotanks might work better. I'm thinking of putting dye in all, and selling my pigment ink(only ones i have), and switching to dye like i should off. Buying a bit of dye, until i sold the pigments would of been smart. Advice when buying a printer these days you have to know exactly what your buying... when i bought the 4760 it didn't even say it was dye, anywhere!. I'm strongly insulted this time and will do much more research before buying any other printer. The workforce 1200$$$ as pigment Ecotank ink. I'll wait for a Ecotank at a reasonable price, and more and more likely from other producers than all the ones we deal with now. I mean 1200$ to use pigment! ink. I wont forget. But i am leaning more and more on dye, which just clogs less(tired), Magenta on my old printer Epson stylus 4800 didn't work, bought the 4760 still doesn't work. They are very annoying, you would think a dye printer would say its dye...Yes it's my fault but its so hard to find "any info" before I always buy the wrong printer, every time!. Product descriptions never say dye or not. I'm getting very frustrated with these companies. The 4760 is the best but it uses precision!!! heads(always something wrong somewhere, be very careful and research any adaptations). Learned from experience that trying to fix magenta will break the printer!. I'll have to print without magenta, that i almost don't use anyway, that why it always failed(C
ut all colours in every page). If a colour breaks and you can't fix it, use the others but don't over clean(E.g. the ink pad might be saturated and your printer will stop! working). I threw away the 4800 and then realized that the error was probably small "parts replacements", but the dealer said he could not get parts anymore(a pad! maybe). My advice is don't play games with any printers they are made to break if not used as intended. E.g. magenta failed, tried to fix it too! much!, printer failed!. If i fix the Magenta I'll let you know how i got there. If not well...Realized that Dye works great also, pigment only works best if extra long storage life is expected. And dye don't clog much! so I'm thinking of going with dye if i can switch again somehow!. Recommended: USE dye! if long term 5Yover printing is needed use pigments
