I'm gonna be straight up. This program is slow, buggy, & can be annoying to use at times. It's not very user friendly & the lack of options can be a bit frustrating.
Putting all that aside, once you figure out the magical NR numbers, the colors that you get from the RAW files are amazing. Nothing else seems to come close to these. I use
RawTherapee & DxO as well, but they can't really match the color output of PDCU. The colors are on another level of awesomeness, even when the ISO starts getting pretty high.
I've attached some parameter files to
this thread that you can use on your images. There are 3 sets of parameter files. These are only for non-pixel shift images. I haven't created any pixel shift parameters. I might eventually do it. The majority of recent Pentax cameras will use the PDCU Natural parameters. The K-70 has its own set & the K-S1 & K-S2 have their own set too. It seems like there were some experimental image tweaks done at Ricoh for the K-S1/S2 & K-70 that don't seem to work the same as all the other cameras. For you K-1 owners, use the regular ones. For the K-1II owners, use the K-70 ones.
You can apply them once you are in the Laboratory mode & going to:
File > Open parameter file...
Then navigate to the PDCU Natural folder & select the file with the appropriate ISO. Use the next highest ISO setting if your ISO doesn't quite fall in the exact setting. Like use the ISO 6400 file for an ISO 4000 RAW image or us ISO 12800 file for an ISO 8000 RAW image & so forth & so on.
The settings are more of a starting point, but a lot of you might find them good right out of the box. The noise reduction settings give the most detail possible, while trying to reduce grain & color noise. Sharpening is set to 0 & they're all set to the natural color tone. You can add more or even reduce NR settings to your liking.
There are some other options that you can play with. You can also apply these to batch a bunch of photos in the Laboratory at the same time. If you have any parameter files that you'd like to share, please feel free to attach them to this thread. You can browse all attachments to this thread by clicking
HERE. Hopefully this will help out some folks that are trying to figure out how to use this program.
