Originally posted by swanlefitte So the Pentax software in camera and on computer is identical. And all raw converters are different. There is that thread 23 raw converters compared.
So my question is Is it impossible to get the same image with different raw processors all the time, in some cases, or it's never impossible with enough work?
I doubt that the Pentax software in camera and on the computer (if you mean DCU) is identical as DCU gets updates where your camera does not. I do not believe that the Prime JPEG engine is updated by firmware, it could be, but I really doubt it.
The whole idea of getting the same image with different RAW processors all the time comes down to, if you get the image you expect and are happy with, why continue to look? Along the lines of losing you keys, searching for them, finding them and putting them into you pocket and then you continue to search for them.
This whole discussion brings me to one of the best reasons to do software upgrades of RAW converters. Each version works differently, some improvements, some not so well worked out "features". Since I use Capture One for most of my RAW (which is pretty near exclusive these days) processing I can tell you outright that version 7 rendered my *ist Ds images quite differently than the current v11. Each time the RAW converter is updated/changed the rendering of RAW images is different with, believe it or not, greater capabilities of
SUBTLE changes are much improved over previous versions. Phase One has done comparisons between its versions touting the "superiority" of the latest version over the previous one.
Yes, to answer your last question, each RAW converter does the "converting" differently than the other. The feature set of any given RAW converter is one of the criteria to be used in your workflow. When using OOC (out of camera) JPEG's you get the cooked interpretation, although you can modify parameters, that is programed into the Prime processor of your camera body. You are more or less stuck with that for the time you use that body.
As I said in a previous thread, I see LR (v6.14) as being more like the Fuji Chrome films, I see Capture One as more of a Kodak type rendering and DCU as Agfa. Each time a RAW converter is updated, it is like you are getting a whole new set of emulsions to work with and for the most part the differences are for the better. Add on to this, I can re-process my old (13 year old) RAW files and it is like shooting them again with all the potential provided by the new rendering capabilities of the converter. JPEG's can not do that.
