Originally posted by Pentaxke It is a pity there still isn't support for K-1 MKII, otherwise I would have upgraded in a heartbeat...
If they ever add K-1 II support, it won't be any different to what you get now, except that you'll be able to process PEF files rather than DNG files.
They won't produce a dedicated K-1 II camera profile that differs in any way what you get when you open a DNG file from the K-1 II in Capture One.
The K-1 camera profile is just a copy of the embedded DNG profile, so I don't expect anything different if K-1 II support ever arrives.
Their claim that they meticulously engineer a custom profile for every camera they support is not true, at least in the case of Pentax. There have been a number of quite bad Pentax camera profiles for Capture One, so I wouldn't hold my breath for anything special. To Phase One's credit, after complaints (and many, many months), they addressed the faulty Pentax camera profiles.
To be clear: I really like Capture One. I much prefer it over LR (which I had used for ~3 years before). C1 (Capture One) is a great RAW editor with much more UI flexibility and better colour editing capabilities than LR.
Sadly, I don't see the value proposition for V12. I'm using two 24" 1920x1200 monitors, so I don't need the increased font size. On the contrary, it will mean that I can fit less on the screen. I don't understand the apparent assumption that everyone is running 4K displays. Actually, font size, font style (the new one is worse), background colour, having tick marks on sliders, etc. should all be configurable. C1 is so configurable in many ways, it just doesn't make sense to force some basic UI choices on users.
The new radial mask tool and the improved gradient mask tool are nice but I feel that they are not optimally integrated yet. The need to rasterise parametric masks sometimes is exposing under the hood limitations to the user, making the latter's life more complicated and inflexible than it should be.
The luma range masking option is OK, I guess, but I've never had the need to create a mask based on luminance values. Pretty much all demos show how you can tame highlights or push shadows, but one could do exactly that with the luma curve before, only in a more precise and controlled manner. Luma masks only bring additional value if your adjustment does not consist in a luminance change.
The new plugin architecture could prove useful to support publishing services (of the like LR has had for a long time) but apparently no access to pixel values is supported so we shouldn't expect anyone to be able and write a "PixelShift" plugin. Too bad.
Overall, this doesn't feel like a proper upgrade and the hefty increase in upgrade pricing is most unfortunate. I think I'll sit this one out.
Still loving V11, though!
